Username Post: 5 speed Camara tranny.        (Topic#337770)
Am4wag
Reg: 11-19-15
07-26-16 03:23 AM - Post#2641826
Does the clutch throw slave cyl.push like the old style/Z bar mechanical or does it pull the throw out arm?
The bearer of gossip is a small untrustworthy person who takes delight in someone else's problems. Avoid them.
Let's all make the day count. - Charlie Daniels
Edited by Am4wag on 07-26-16 03:25 AM. Reason for edit: No reason given.
DECEASED
07-30-16 09:49 PM - Post#2642707
    In response to Am4wag
You didn't specify a year, so I will assume you are asking about any stock 3rd gen with factory hydraulic linkage. The slave is the push type, as can be seen here:
http://www.hawksmotorsports.com/camaro-firebird-82...
Right click on the image to enlarge.
Execution time: 0.008 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:24 AM
