Username Post: Question on Transmission 200 4R        (Topic#366451)
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
09-19-21 11:46 AM - Post#2827407
Question! What would a ( one ) tooth difference make on the driven gear on a speedometer in either m.p.h. or in a percentage. Does anyone know ?
Remember,I'm not always right. But I'M never WRONG !
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
09-19-21 11:55 AM - Post#2827408
    In response to pauldian
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
09-22-21 01:51 AM - Post#2827664
From my own experience, one more tooth will decrease MPH by 4-5MPH. One less tooth will increase MPH by 4-5 MPH.
Vern
1930 DeSoto Business Coupe- 350 Chevy V8, EFI, 4-wheel disc brakes, Wire Wheels, TH400, S-10 Rear, A/C
paulo57509
Loc: CA
Reg: 07-18-00
09-22-21 02:47 PM - Post#2827713
There are gear calculators online. You'd have to know what you have in there now (drive and driven gear teeth), tire diameter and differential gear ratio.
You should be able to back into an answer.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Edited by paulo57509 on 09-22-21 02:47 PM. Reason for edit: No reason given.
Member #409
09-22-21 05:56 PM - Post#2827733
    In response to paulo57509
On a 200-4R, there are effectively 2 speedo gears that you need to pay attention to. First one is the gear that's on the speedo output. That gear is similar to many other GM transmissions. Second one is the gear that drives it, which is on the governor assembly. I think all that's covered in the speedo gear article at TCI Transmissions website. Been a while since I've been there, hope it's still there.
65_Impala
Reg: 12-29-02
09-23-21 08:53 AM - Post#2827780
If you know the number of teeth on the gear you currently have then it's a simple ratio. Say you have a 30 tooth gear. Going to 29 teeth would change the speed by 29/30 = 96.7%. Going to 31 teeth would change the speed by 103.3%.
The exact amount will change depending on the number of teeth on the gear you currently have so there is no simple fixed percentage answer. But the answer will always land in the 96-97% and 103-104% range so you could say changing a tooth would cause the speedometer reading to change by 3.5% which is likely close enough if you only need a single tooth change. I would calculate the ratio if you need a bigger adjustment.
pauldian
pauldian
Reg: 05-14-09
09-23-21 09:44 AM - Post#2827789
    In response to 65_Impala
I have the green 10 tooth drive gear and the 27 tooth driven gear which T.C.I. recommended and I'm still about 2 m.p.h slow on the speedometer. I ordered a 26 tooth gear and now I'll see where that go's. The closes one wins.....
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
09-24-21 02:17 AM - Post#2827848
I think that will put you very close but maybe a hair over. You may not be able to get it exact.
Vern
65_Impala
Reg: 12-29-02
09-24-21 04:51 PM - Post#2827899
Say you are showing 58mph when running 60mpy so take 58 times 27 divided by 26 you get 60.2mph. Let un know what really happens.
Execution time: 0.601 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:59 AM
