Username Post: Sizing Electric Fan        (Topic#365455)
DucatiRod
Loc: Maine
Reg: 12-31-20
06-07-21 04:22 AM - Post#2821267
I read somewhere that 2700CFM would be the right size for a lightly warmed over 327. I don't know for sure that this info is right, and I found it hard to find any fans of this size! So, the questions become, what's the range, size wise for a SBC, what are the safe brands to buy, and what features should I be looking for so that I won't end up with buyers remorse~ Thanks in advance for the help!!!
06-07-21 07:27 AM - Post#2821278
    In response to DucatiRod
Use dual fans. If one fan fails, the other can keep it cool enough to keep it from over heating. Spal is top notch. Use separate relays for each fan. My ZZ4 runs a dual fan LS Camaro set up. Both fans turn on at 205 F and off at 190 F. The engine stays close its operating temp of 195.
'08 GMC Acadia 3.6L SLE
65_Impala
Reg: 12-29-02
06-07-21 09:03 AM - Post#2821280
Yes, dual fans are the way to go, unless you go with a big brushless fan.
A trend these days is to use a PWM fan controller, which will vary the fans speed so they're not so loud all the time. It's also easier on the fans and electrical system by removing the high switching currents.
If you use relays, get good relay bases or screw terminal relays. The terminal clips in a good relay base should look like a Packard 56 terminal, not those cheesy rolled edge ones.
DucatiRod
Loc: Maine
Reg: 12-31-20
06-07-21 12:17 PM - Post#2821293
    In response to 65_Impala
Who ever thought that setting up a fan to cool an engine now-a days, would cost more than my first engine rebuild back in '67 or '68
Member #409
06-07-21 06:43 PM - Post#2821315
Don't be fooled by cfm ratings. They will lie to you or rate them using misleading conditions. Use current draw instead.
Actually the best approach is to use the most you can fit in the space. The dual fans are usually what fits that description. Use a name brand or adapt an OEM fan.
06-08-21 03:11 AM - Post#2821324
    In response to Rick_L
For a single fan, go big. Lincoln Mark VIII fans are great. My '00 Ram is getting one installed. I fit it into a stock shroud. The fan is bigger than the metal stock 5 blade fan. To control dual speeds, I'm using a Volvo relay. Low speed for A/C cooling. High speed for temp cooling if 195+ F is reached.
65_Impala
Reg: 12-29-02
06-08-21 05:53 AM - Post#2821335
Where'd you find a Mark 8 fan with 2-speeds? The stock ones weren't 2-speed. They have 3 terminals and lots of 2-speed assumptions were made, but they didn't have 2 speeds.
Mel Foye
Mel Foye
Reg: 09-29-00
06-08-21 12:25 PM - Post#2821356
I don't remember the numbers of speed but I had one and even with 2 really small jump wires when the wife touched them to battery it came really close to twisting out of my hands. Big air mover.
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
06-08-21 03:12 PM - Post#2821365
Probably a Taurus fan, looks similar and 2 speed.
For the old 28x17 core radiator GM used in umpteen million vehicles the Nissan NV200 fans fit like a glove. Dual fans in a shroud and each have a 2 speed motor. Motors are simple to wire as well. One set of coils to power and ground you get low speed. Hook up the 2nd set and power both and you get high speed. Lots of CFM. You can get the set for a little over $100 new aftermarket if you shop around. Chevy City Express is the same van. So its an OEM Chevy part as well.
https://www.partsgeek.com/gbproducts/AC/125095- 042...
Edited by 1983G20Van on 06-08-21 03:17 PM. Reason for edit: No reason given.
06-12-21 11:33 AM - Post#2821526
    In response to 1983G20Van
The fan is two speed. I've tested it with a portable 12V booster. High speed sucked debris out from a truck bed. The fan was leaning on the bed cover with an open tailgate. I have a picture of it somewhere. It's mounted but still not sealed to pull only through the fan shroud.
Execution time: 0.008 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:19 AM
