Username Post: locked up block        (Topic#360136)
995jim
995jim
Loc: Ohio
Reg: 12-17-06
03-12-20 12:09 PM - Post#2788505
I have an 348 engine block fully assembled except intake that wont turn by hand. I don't plan on rebuilding it but thought if I could fill the cylinders and douse cam under the intake manifold I may be able to loosen it. Not sure what a good product would be, (diesel,kerosene,5-30 motor oil ?). I didn't want to make an investment just to experiment with freeing it up. If it doesn't work Im not worried but thought its worth a try. No water in oil pan, but the pan is empty.
thanks jim
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
03-12-20 03:51 PM - Post#2788519
    In response to 995jim
Last time I freed up a frozen engine I used ATF on top of the pistons. Replenished regularly and let it soak for about 60 days. Then I hit the tops of the pistons with a 2x4 and mallet.
It was a Model A engine with the head removed.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
03-12-20 04:50 PM - Post#2788525
    In response to paulo57509
Edited by grumpyvette on 03-12-20 05:42 PM. Reason for edit: No reason given.
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
03-12-20 08:40 PM - Post#2788537
    In response to grumpyvette
I use ATF and Acetone myself.
995jim
995jim
Loc: Ohio
Reg: 12-17-06
03-13-20 05:43 AM - Post#2788545
    In response to 1983G20Van
thank you for the information giving me a path forward. As always a great site to come to.
jim
1carguy
Reg: 11-30-08
04-06-20 01:22 PM - Post#2790502
I once freed up a frozen up boat motor by removing plugs and soaking the combustion chambers with Marvels Mistery Oil and letting it soak a day or so. Motor freed up and ran fine until I sold it a couple of years later. That stuff really worked for seized up rings.
Am4wag
Reg: 11-19-15
04-06-20 04:58 PM - Post#2790515
    In response to 1carguy
I freed up a pair of 903 Cummins in a Chris Craft that sat for 11 years.Marvel Mystery Oil through the air dams.Got them both running in a little over a week.Ran down Alabama rivers from Port Birmingham to Pennsecola Fla.
The bearer of gossip is a small untrustworthy person who takes delight in someone else's problems. Avoid them.
Let's all make the day count. - Charlie Daniels
Execution time: 0.011 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:02 AM
