Username Post: small block cracks        (Topic#355036)
corvesy
corvesy
Reg: 08-07-08
01-31-19 11:37 AM - Post#2758665
I am going to look at a 327-300 in the next few days to buy based on inspection. My question is where would cracks typically appear? I know to look in the head/valve area, but where may the other typical cracks occur.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-31-19 11:52 AM - Post#2758668
    In response to corvesy
lifter bores
and lifter gallery
,piston bore walls,
block main cap web support areas
heads between the valves in valve seat area
look for stripped head and manifold and oil pan mounting bolt threads,
in threaded holes and cracks in block radiating from the holes
Edited by grumpyvette on 02-08-19 02:19 PM. Reason for edit: No reason given.
01-31-19 04:13 PM - Post#2758693
    In response to grumpyvette
Nicely done, Grump. Another area I've seen is between the freeze out core plugs on the sides of the block, usually caused by freeze ups.
Edited by Shepherd on 01-31-19 04:54 PM. Reason for edit: No reason given.
corvesy
corvesy
Reg: 08-07-08
02-01-19 08:09 AM - Post#2758739
As Shepherd said great info, I really appreciate it. I was planning on a visual inspection plus spray on crack penetrate in the problem area's. Thanks Grump.
Techhead
Techhead
Loc: Etobicoke, Canada
Reg: 10-25-05
02-08-19 02:15 PM - Post#2759407
Core shift would be another one to look at.
58 Delray in disaray
Execution time: 0.015 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:47 PM
