Junk86
Reg: 03-15-19
01-23-22 02:45 AM - Post#2835074
1973 Chevy Nova Auto Trans Column Shift Tube Lever.
Unable to attach the steering upper rod to the column shift lever tube bracket on the column. The bracket is positioned all the way upward towards the bottom of the firewall. I believe, it is located in the lowest range (L) in that position.
Must I rotate that lever down towards the ground to get it into the Park Position? This is my question.
Edited by Junk86 on 01-25-22 02:24 AM. Reason for edit: No reason given.
01-25-22 07:57 AM - Post#2835206
In response to Junk86
all the way up should be park all the way down should be low gear. the rod should be adjustable
Junk86
Reg: 03-15-19
01-26-22 02:46 AM - Post#2835243
In response to bobb
Thanks for that reply. One more question, if the steering upper rod is not attached will that cause my back-up lights not to work. I lost the rod and now I have no back-up lights. If that is not my problem, then what is my alternative to getting them up and working again?
01-26-22 09:21 AM - Post#2835256
i dont understand steering upper rod. reverse lights should work from switch on the steering column i think. check bulbs and fuse first.
Junk86
Reg: 03-15-19
01-26-22 09:48 AM - Post#2835257
In response to bobb
The steering Upper Rod is the linkage rod that attaches to the steering shift tube Lever.
I have been informed that this rod must be attached in order for the back-up light switch to operate, which is located inside the Steering Shift Tube.
If you turn the ignition switch to the start position, you can rotate that lever by hand, but it must be returned to the park position, in order,to have the ignition switch return to the fully closed position.
