Username Post: Rack and Pinion conversion        (Topic#346989)
ratnfested
ratnfested
Loc: Rochester, NY. USA
Reg: 03-13-00
09-05-17 10:19 AM - Post#2706740
Hi all. Its been a while. I am looking to start a R&P conversion on the Chevelle. I know kits are made for 68-72 chevelles and there is one for 75-81 F body. and we use the same sway bar as the Fbody so I am am wondering if the frame spacing between the gear box and the idler arm are the same or close. I have to find a buddy with an F-body of that gen and see what the measurements are. Has anyone done one and have any input for me?
Oh BTW I put a 4l80E in the Chevelle last winter. Used a TCI/FAST controller. Works pretty nice. Shifts good. Not happy that the controller cannot individually tune the shifts. If you want to firm up 2-3 you have to firm up all of them.
Philip Ferrera
1977 Chevelle
1977 Malibu Classic
1986 Grand Prix
1995 Tahoe
2003 Impala LS
2004 Ski Doo REV
Street Machines of Rochester NY
DECEASED
09-05-17 12:59 PM - Post#2706753
    In response to ratnfested
I'm not sure if such a R&P conversion exists, unless you want to go to a complete crossmember swap like a M-II or one of its clones.
Just out of curiosity, what do you expect to gain over the stock PS gear and linkage? I have driven the stock setup and it didn't seem all that bad.
ratnfested
ratnfested
Reg: 03-13-00
09-06-17 06:13 AM - Post#2706803
I am hoping to get the feel of a tight steering with no play. Like a newer vehicle. I put urethane bushing and new sway bars in the car and it handles really nice. The steering would be a nice addition to complete it. I did buy an AGR box a few years back but I do not really like it. It is a 12:1 but seems to have more assist to the right than left. And still has that inherit play that gear boxes have. In looking at the kits out there, they have a frame that mounts where the gearbox and idler arm go. If I could find the dimensions for another vehicle are the same or close I might be able to make one fit.
Philip Ferrera
1977 Chevelle
1977 Malibu Classic
1986 Grand Prix
1995 Tahoe
2003 Impala LS
2004 Ski Doo REV
Magno99900
Magno99900
Loc: Pittsburg, CA
Reg: 01-01-05
09-08-17 08:43 PM - Post#2707114
If you want the feel of rack and pinion, just switch to a 600 series gear box (turn one or lee, just some that came to mind quickly)
They are lighter and bolt right in. They use the exact same valving as a rack and pinion set up so they have nice tight center feel.
ratnfested
ratnfested
Reg: 03-13-00
08-27-18 06:44 AM - Post#2744528
    In response to Magno99900
I have an 800 series now. I am told those are built better all steel and its a 12:1 nice and tight. I just thought a R&P would be a step up.
Philip Ferrera
1977 Chevelle
1977 Malibu Classic
1986 Grand Prix
1995 Tahoe
2003 Impala LS
2004 Ski Doo REV
08-27-18 07:35 AM - Post#2744539
Besides the more precise feel of r and p, another big advantage of this change is getting rid of the pitman, center link and and idler arm, added up all points of poor steering response if they are even slightly worn.
10-18-18 07:53 PM - Post#2749017
The mounting of the unit is a secondary concern. The factory mounts are usually two bosses cast into the housing and are pretty close together. You can get a framework fabbed up to securely mount the rack to the frame and the frame to your cars frame. Your main concern should be the width of the main part of the rack itself. Your pivot points for the tie rods should be at a width very close to the distance between the forward mount bolts for your lower control arms. If this measurement is not close you can get severe bump steer. You will also have to make sure your power steering pump is putting out the correct pressure for the rack.
1957 Cameo Carrier
Execution time: 0.018 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:17 AM
