Username Post: 67 chevelle brakes fit 68 chevelle ?? drum brakes, both cars        (Topic#365525)
rockin rebel
rockin rebel
Loc: Langley, BC. Canada
Reg: 03-31-11
06-15-21 03:39 PM - Post#2821649
have 68-72 frame with zero brakes. my buddy has all the fronts from a 67.. can I use them. I am a Chevy guy and know, so much will interchange, even though they have a slight difference, and different part numbers...thanks
Edited by rockin rebel on 06-16-21 03:09 PM. Reason for edit: No reason given.
bel-air 62
Reg: 01-16-05
06-16-21 02:21 AM - Post#2821657
    In response to rockin rebel
Are you talking about complete brakes including spindles? If the brakes you are talking about are disc brakes the 67 and 68 both used four piston brakes and I wouldn't put them on unless they were correct for a restoration.
rockin rebel
rockin rebel
Reg: 03-31-11
06-16-21 01:45 PM - Post#2821680
    In response to bel-air 62
rockin rebel
rockin rebel
Reg: 03-31-11
06-16-21 01:48 PM - Post#2821681
[image]https://[/image] dont know what is going on with the site, but no, drum brakes all around, both cars
bel-air 62
Reg: 01-16-05
06-17-21 02:15 AM - Post#2821706
I don't think it would be a problem to use them if you use the complete brake with spindles.
Execution time: 0.007 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:22 AM
