Username Post: Power steering fluid 67 Chevelle        (Topic#360137)
J REID
J REID
Loc: SW Minnesota
Reg: 04-09-04
03-12-20 03:00 PM - Post#2788515
I am on the tail end of assembling the power steering kit from Ground Up which came with no instructions. Never having worked with ps before I bought power steering fluid & after I got the system all primed & leaks fixed, found out that it is supposed to have type A trans fluid. Are there any knowledgeable out there that could advise me? Sure wish I would have done a little looking before I jumped. Thanks
57 210 4dr, 57 2dr ht project, 67 Chevelle SS project, 40 Chev coup project
elcamino
elcamino
Reg: 03-30-00
03-13-20 05:36 AM - Post#2788544
    In response to J REID
Type A Transmission Fluid was introduced in the mid 1950’s for use in all automatic transmissions for General Motors vehicle brands. Type A was used through the mid 1960’s. Its obsolete.
GM claims all formulations of Dexron ATF are backward compatible.
2017 GMC Sierra Denali Ultimate 6.2L / 8-sp Z95
2018 Polaris RZR S 900 EPS
2016 Polaris RZR 900 EPS
ragtp66
Reg: 12-09-07
03-15-20 07:39 PM - Post#2788728
    In response to elcamino
Sacrilegious I know but the Type F (Ford) trans fluid is as close to the original type A fluid as you can find. That is what I use in my old cast iron powerglide in my 58 Impala.
Toys:
1987 Sea Ray Pachanga 22
Execution time: 0.008 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:08 AM
