PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
01-21-25 01:20 PM - Post#2877300
I have a 2023 Trailblazer, and the cruise control stopped working. Before I take it in for service I would like to check to see if the fuse is ok, but this thing has a qazillion fuses and I haven't found exactly which one it could be. Any ideas of what number the fuse would be and which fuse box? Any other thoughts welcome. Thank you in advance.
01-21-25 01:46 PM - Post#2877303
In response to PLS
Should be in the owners manual, or on the underside of the fuse box cover.
PLS
Reg: 06-07-12
01-22-25 08:50 AM - Post#2877311
Well, this is a little embarrassing. This is primarily my wife's car, and she never uses cruise control, I can't drive without it. Once you turn the control on it stays on until you turn it off, so you just have to set it when you want it to operate. Either me or my wife must have turned it off while turning on the steering wheel heater and I failed to see that the cruise control light on the dash wasn't on. The two buttons are really close to each other. Appreciate the hellp for this dummy.
01-25-25 06:34 AM - Post#2877363
In response to PLS
Too many gadgets! The heated steering wheel is nice though!
'08 GMC Acadia 3.6L SLE
