Username Post: 700R Trans. HELP        (Topic#360247)
Hiosilver
Reg: 03-22-20
03-22-20 11:58 AM - Post#2789252
I have a 86 Silverado that the 700R Trans all of a sudden stopped shifting into OD. Any suggestions as to where to start looking for a resolution.
03-22-20 12:03 PM - Post#2789253
    In response to Hiosilver
Welcome to the site. Does it have RPM gauge? Are you sure it's not shifting too early or late into OD? Check the TV cable before driving again. Use this method to adjust the cable.
http://www.73-87.com/7387garage/drivetrain /tvcable...
Is the lock up converter working?
Hiosilver
Reg: 03-22-20
03-22-20 08:18 PM - Post#2789281
Yes I have a tack and no drop on rpm
I will check the tv cable tomorrow.
Thanks for your quick responses
Execution time: 0.012 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:16 AM
