Username Post: Gold wrapped emblem        (Topic#358257)
09-29-19 05:57 AM - Post#2776682
A friend of mine does wrapping. Since the bow tie on BADBOW was looking bad, I had him wrap it for me. It looks great! Now the problem is how to put it back on. Double sided tape will not work. The aftermarket piece does not have studs. A plastic hot weld was recommended.
Attachment: wrap1.jpg (135.6 KB) 14 View(s)
Wrapped emblem.
Attachment: wrap.jpg (82.69 KB) 13 View(s)
Grill emblem
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
09-29-19 08:18 AM - Post#2776695
Do you have it installed already? My experience with hot gluing parts, both surfaces should be warmed (hair drier or light heat gun) so the glue will stick much better cause surfaces are cooler than the hot glue. May be same for plastic weld too, but I'm not too familiar with the plastic weld.
1974 Cheyenne 10 LWB 350/TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
09-29-19 09:37 AM - Post#2776702
    In response to Liberty Valance
Not yet. The emblem held on from vinyl wrap. It's thick enough to keep the bow tie ends from touching the grill. I suspect my friend was saying hot glue parts in instead of weld. Once I remove grill, I'll find a way to put it on.
2plus2
Loc: Mission,BC
Reg: 02-03-05
09-29-19 10:46 AM - Post#2776706
I would use this
https://www.amazon.com/3M-03615-Scotch-Mount -Moldi...
69 Canadian Pontiac 2+2
100 CHEVY
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
09-29-19 02:50 PM - Post#2776723
Go to an auto glass place and have them put a spot of urethane on it.
You'll never get it off again!
Mike.
09-30-19 05:35 AM - Post#2776752
    In response to 100 CHEVY
It needs to be removable in case the vinyl ever tears or peels off.
A 3M double sided tape roll is on order. The roll is wide at 7/8". I can use some to tape Velcro for a front SUV bra. When I glued it on last time, I used rope to hold/bend it in place. I'll probably have to do it again.
BoniOni
Loc: Austria
Reg: 12-04-05
10-01-19 02:46 AM - Post#2776815
nice bowtie!!
I would not trust a double sided tape, it could fall off with the heat or will not be easily removable otherwise. If the emblem has enough thickess I would make drill holes (1/8" in depth or so) and install studs, which I would glue into these holes and have nuts on the grille side or otherwise, if the emblem's backside is shallow then something like an u-shaped piece of metal with an opening width like the width of the holes in the grille where I'd firmly glue the middle part to the emblem and make/have treads on the ends that go through the grille and mount also with nuts.
10-06-19 12:27 PM - Post#2777188
    In response to BoniOni
Attached is an emblem backside pic. The wrap is thick enough not allowing the emblem to slide on the grill square molding.
BoniOni
You have some great ideas. I like the metal bent U. Some aluminum stock and file might do it.
Attachment: gold2.jpg (77.39 KB) 10 View(s)
Emblem backside.
Attachment: BADBOW.jpg (195.39 KB) 11 View(s)
Tailgate weekend at a friend's house.
BoniOni
Loc: Austria
Reg: 12-04-05
10-07-19 09:00 AM - Post#2777263
Hi gchemist,
cool truck that you have. I am glad I could inspire you a bit, we should keep in mind that GM did every part solid (and exchangeable) so I see it as our "duty" to do it so as well for each add-on. aluminium or some "softer" metal is a great approach, maybe you can go without threads and mount it with those retainer nuts usually used by Gm for emblems. for putting together the u-piece and the emblem I would either use the mentioned uretane or some good glue, however I would be careful with a hot glue/weld since your emblem wrap could warp from the heat.
Execution time: 0.282 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:37 AM
