Username Post: Chattering PCV valve issue solved        (Topic#356754)
Cattle48
Reg: 02-04-15
06-10-19 08:13 AM - Post#2768106
Well I posted my issue with the PCV valve that had a loud chatter ... Turned out to be a leaking fuel vac line at the tank. Found out by clampimg off both the vac lines from the canister. Now I need to get to those small tank rubber lines and replace them ... Just thought I would let you know what I found ... May save some time for someone else.... MIke
06-10-19 08:46 AM - Post#2768109
    In response to Cattle48
Cool. Be sure to use fuel rated hoses.
Cattle48
Reg: 02-04-15
06-11-19 08:27 AM - Post#2768217
Will do... Trying to figure out the best way to get at the hoses ... in a hard place to get to .. Dont really want to have to lower the tanks but short of taking the bed off I don't know an easier way do you have any better ideas ... Mike
06-11-19 09:05 AM - Post#2768220
Loosen the bed and tilt it. I've done it. Using a 2X4" or blocks to hold up the bed.
Cattle48
Reg: 02-04-15
06-13-19 08:32 AM - Post#2768373
Will do .. I sure don't want to have to do it agan HA ... Mike
Cattle48
Reg: 02-04-15
06-13-19 08:35 AM - Post#2768374
Tnx I will try that ... I got some heavy tool boxes that will have to come out to do it but I figure I'll replace both sending units while in there? Is that the best way to get at the dual tank fuel valve too ?
06-14-19 05:05 AM - Post#2768427
If I lift the bed off my truck again, I'm replacing both sending units. Worth the time. I've used an engine hoist to lift it by myself. I do have to take the bed off one more time. The bed will get rust proofing and cleaning. Frame and axle will get paint too. A behind the roll pan hitch will also be strengthened for use.
Edited by gchemist on 06-17-19 11:04 AM. Reason for edit: No reason given.
Cattle48
Reg: 02-04-15
06-17-19 08:24 AM - Post#2768667
Yeah good idea... I'll have to think about that when I figure out which way to guse to get at the hoses ... May be able to use the A frame to lift the bed off ... ? ... Just hae to get up the get up it will take to start that project and get all the tank parts together first then make myself do it HA HA ... For some reason I just have not been able to make myself get going on it .. I use the old truck everyday with the stock trailer and I know I'll be without it for a while ..But it has to be done ..Mike
06-17-19 11:07 AM - Post#2768687
Copy this with wood!
http://www.whosyadaddy.com/pickuppal.htm
An A frame and lift balancing the bed will work.
Execution time: 0.015 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:09 AM
