Username Post: 72 chevy cheyenne super seam sealer        (Topic#361203)
hinges56
hinges56
Loc: Canyon Lake ,Ca.
Reg: 06-01-08
05-30-20 07:43 PM - Post#2795281
My seam sealer on the roof drip rails is cracking badly and the roof drip rails are rusting. What is the best seam sealer to use? Two part? Self leveling? Could water get into the cab area by the vents on the floor? Thanks, Scott
49erman
Loc: So Cal Lower Desert
Reg: 01-02-18
05-31-20 12:21 PM - Post#2795319
    In response to hinges56
3 M #08531 is what a local Body Shop uses. The rust needs to be all gone first before any primer sealer and seam sealer is used. I myself sandblasted all the drip rail area then blew the s h i t out of it to get all particles dust and such gone then primer sealed it and used Body putty/filler sanded it all smooth then topped it off again with primer sealer. That's it.
PS not that it matters I also am 68 and live close to you in yucca valley.
Edited by 49erman on 05-31-20 12:25 PM. Reason for edit: No reason given.
Execution time: 0.011 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:44 AM
