Username Post: 1970 Jimmy roof interchange        (Topic#345269)
tabber
Loc: St. Paul, MN
Reg: 06-09-07
06-06-17 04:17 PM - Post#2694784
Hey everyone, new to the Jimmy/Blazer trucks. I need a new top for mine and was wondering what years I can use, and also I read somewhere there is both a single wall and a double wall version. Can I use either? Anything to watch out for when buying one? located in St. Paul, MN. Going to check one out this weekend up in Duluth.
tabber
Loc: St. Paul, MN
Reg: 06-09-07
06-07-17 04:41 AM - Post#2694865
    In response to tabber
Anyone have any info on differences between 1970, 1971, 1972 Blazer roofs, and single verse double walled interchangeability?
JimKshortstep4x4
Chevytalk Moderator & "16th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
06-07-17 04:34 PM - Post#2694967
The two tops should interchange between the years. The hold down bolt spacing looks to be the same. The double wall bolts to the bed sides with the fasteners going up into the nuts that are in the side walls. On the single wall the hold down bolts go through the flange into the bed which has welded nuts in it.
I believe there is a difference in the hatch so you will want to make sure the hatch has the right hardware with it.
My son's Blazer top is in my garage, so if you need any measurements from a 72 double wall top, I can get those for you.
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
tabber
Loc: St. Paul, MN
Reg: 06-09-07
06-07-17 05:32 PM - Post#2694976
Good info, thanks. Are good shape doors easy to find, I see a repo for 600.00 which is more then I want to spend at this time.
JimKshortstep4x4
JimKshortstep4x4
06-08-17 04:24 PM - Post#2695127
Truck doors can be converted fairly easy if Blazer doors are not readily available.
If you want to modify a truck door, I can email you the information that you would need.
Door latch reenforcement is needed but they can be taken from scrap Blazer doors.
Execution time: 0.134 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:39 AM
