Username Post: Accelerator Pedal-firewall mounted        (Topic#366565)
persh
persh
Loc: Tucson, Arizona
Reg: 07-19-00
10-02-21 06:28 AM - Post#2828375
I'd like to find the parts to be able to mount my gas pedal assembly to the firewall instead of having the pedal pivot on the floor. Any suggestions??
'60-'66 Idea Page or Corvair Stuff
Senior Moderator
10-02-21 06:52 AM - Post#2828377
    In response to persh
Hey Persh,
Check out the GMT400 truck (1988-1998 body style) gas pedal; sounds just like what you're looking for. Skip the diesel trucks unless it's pre-1994 as those are electronic. Should be plentiful and inexpensive in the boneyards.
jktucker92
jktucker92
Loc: West Richland, WA
Reg: 02-05-17
10-03-21 09:17 AM - Post#2828428
    In response to someotherguy
I agree. I used a pedal out of a early 90's truck when I put a TPI motor in my '65 truck. It allowed me to put a cable throttle linkage in for the TPI throttle body. I used screws to attach it to the firewall, and then cut a hole in the firewall with a square hole to match the stock application. As I recall, I ended up bending the end at a right angle for clerance reasons, and it also allowed more pedal travel for the throttle.
Execution time: 0.007 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:30 AM
