Username Post: 1965 c10 Newbie Fusebox question        (Topic#359377)
jbaker400
Reg: 10-12-19
01-05-20 07:04 AM - Post#2783722
hi,
Probably a stupid question.... but wiring is not my thing! I did however wire up an electric fuel pump with a relay.
Someone will know the answer right off the bat....
I need one wire to go to direct power all the time, and another to go to power during ignition only.
Where do I go to the fusebox for each of these?
thanks!
1965 c10 fusebox
01-05-20 11:02 AM - Post#2783744
    In response to jbaker400
what are you powering? its a good idea to fuse or circuit break everything.
jbaker400
Reg: 10-12-19
01-05-20 08:58 PM - Post#2783782
    In response to bobb
Hi
One goes to oil pressure switch and the other is to the relay
01-07-20 07:39 AM - Post#2783905
oil pressure switch controlling the relay?
Woogeroo
Woogeroo
Loc: what does this part do?
Reg: 05-26-02
01-13-20 05:19 PM - Post#2784351
If you have a test light or a digital multi meter, you can just check the circuits for 12v(with the meter anyway) with the ignition on.
add a fuse block
If you look at the after shot photo, the 3rd one down, is the heater fan circuit, it is a 12 volt ignition hot. It also has the slide on piece on the side for the wire/connectors.
I setup a separate circuit that runs off a relay of the ignition hot, for my radio... it's pretty straight forward to do.
-W
jbaker400
Reg: 10-12-19
01-13-20 08:47 PM - Post#2784363
    In response to Woogeroo
thank you.
Woogeroo
Woogeroo
Reg: 05-26-02
02-24-20 05:40 AM - Post#2787177
you are welcome, hope you got it sorted out.
-Woog
Execution time: 0.02 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:26 PM
