Username Post: Power Steering column question 66' C-10        (Topic#357714)
Verona
Reg: 02-08-19
08-19-19 09:05 AM - Post#2773548
I have a 66' C-10 on a No Limits chassis with 88-96 Thunderbird power steering rack. The small port is a pressure 14mm o-ring, large port (return) is 16mm o-ring. The u-joint size is 3/4x36x34DD.
What else do I need to figure which power steering column to purchase? (I'm a 54 y/o grandma putting my first truck together... Have patience and mercy!)
Also; any suggestions where to get quality AC vents? I've added Vintage Air and the provided vents are not high quality.
Execution time: 0.014 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:35 AM
