Username Post: serious question about oversized tires        (Topic#356043)
Bad-Karma
Reg: 02-22-16
04-16-19 11:51 PM - Post#2764368
I've been slowing working on a 63/64 Chevy C10 for a few years (resto-mod). Finally got the body to primer and now, I'm starting to consider tires.
I saw a meme of a 70's/80's RV with oversized tires; like HMMWV (or Humvee®) sized tires (37x12.50R16.5)... the more I look at it the more I think it would look awesome on my truck.
The time is pretty good because I need to rebuild/mod the suspension. I'm thinking of upgrading the suspension to 3/4 ton (a friend has an extra set he pulled off a truck) but I'm wondering if an aftermarket would be better.
Edited by Bad-Karma on 04-16-19 11:52 PM. Reason for edit: No reason given.
04-18-19 08:45 AM - Post#2764470
    In response to Bad-Karma
taller tires will make your brakes weaker. 3/4 suspension will make the ride stiffer.
Execution time: 0.016 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:39 PM
