Username Post: Oil Pressure gauge line fittings for 1956 chevy 3100        (Topic#375141)
56db
Loc: Scotts Valley, CA (95066)
Reg: 01-29-13
06-04-24 03:15 PM - Post#2870483
UPDATE. Found the part.
Would anyone know who sells the original style one piece brass oil line fitting, 5/16"-24. The nut and ferrule end are one piece?
I need 1 for the block and the gauge.
I've checked with all the local hardware and Auto parts stores.
I was told the 2 piece brass oil gauge fittings that have separate ferrules can be trouble.
This will be for the 1/8"copper oil line coming from the block to the oil pressure gauge on a 1956 Chevy 235-6 . Thanks
Edited by 56db on 06-05-24 12:05 PM. Reason for edit: No reason given.
Midi
Midi
Loc: Jacksonville, Florida
Reg: 06-04-09
07-04-24 06:59 AM - Post#2871446
    In response to 56db
You are looking for a 1/8" Threaded Sleeve Nut offered by Weatherhead item # 6100X2. I found them on McMaster Carr.
Execution time: 0.009 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:09 PM
