Username Post: Rear Brakes        (Topic#360609)
sting199
Reg: 12-12-19
04-21-20 09:58 AM - Post#2791694
I have replaced disk pads on all of my cars in the past, but got to my 79 Vette, and the rear brakes have a steel line running to the calipers. So, every time you have to change the pads, you would have to disconnect this line and rebleed the brakes when installed? Never saw this setup before. The fronts have a flex line.
TAT_2
Member #26 "19th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
04-21-20 03:04 PM - Post#2791718
    In response to sting199
NO NEED TO REMOVE THE CALIPER,PULL OUT THE PIN,THE PADS COME OUT THRU THE TOP,REVERSE PROCEDURE.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Execution time: 0.014 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:37 AM
