Username Post: 90's TBI 350 Chevy v8 injectors won't spray        (Topic#326727)
maherc84
Reg: 07-18-15
07-18-15 04:55 PM - Post#2562541
Fuel getting all the way through the fuel rail to the injectors.... Injectors not spraying. Replaced distributor cap as it was shot. Replaced rotor button. Replaced ECM. Getting spark from the ignition coil but I'm not sure if it's enough.... Unplugged the 3 prong plug on the side of the motor and the water pump looking plug both what I thought were the TCM's.... I'm at a loss... Just trying to help a friend but I hope I'm not in over my head.
Edited by maherc84 on 07-18-15 04:56 PM. Reason for edit: No reason given.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
07-19-15 02:24 PM - Post#2562693
    In response to maherc84
Make, model and year please.
WyrTwister
Loc: South Central USA
Reg: 09-20-15
09-20-15 09:19 AM - Post#2576855
Is this a throttle body fuel injection system ?
God bless
Wyr
WyrTwister
Reg: 09-20-15
09-26-15 01:24 AM - Post#2578252
    In response to WyrTwister
If it is TBFI , I read they make a small device called a Noid light ;
https://search.yahoo.com/yhs/search?p=noid+lit e&am...
You unplug the electrical connector from the injector & plug the Noid light into the connector .
Try to start the car . If the electronics is generating the electrical pulses to male the injector pulse , the light should flash .
Test both injector connectors . If the Noid light does not flash , the problem lies elsewhere in the electrical / electronics of the car .
If the Noid light does flash , for both connectors , I would guess the injectors are bad or not getting gasoline . I think there are screens that can be replaced . Also a pressure regulator .
God bless
Wyr
God bless
Wyr
WyrTwister
Reg: 09-20-15
09-26-15 01:44 AM - Post#2578253
Im just dug out my book with the wiring diagram . You should have a 7.5 amp fuse that powers the injector circuit , in the fuse box . Check it & check ( with fuse un plugged ) is one side of the fuse " socket " is hot - 12 VDC ?
God bless
Wyr
God bless
Wyr
Edited by WyrTwister on 09-26-15 01:45 AM. Reason for edit: No reason given.
JPC1990
Reg: 05-05-21
05-05-21 07:07 PM - Post#2819366
I just finished working on my 1990 TBI 350 for almost the exact problem. Mine was running fine, shut it off went in for the night, came out next morning and it would only turn over but would not start. It was not getting fuel into the throttle body. After extensive checks, and some parts replaced, I found that the Ignition Module was the problem located under the distributor cap. Tax and all, at Oreilly’s, was around $60.
Execution time: 0.462 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:38 AM
