Username Post: Chevy k2500 1989 6.2D dies when letting off accelerator fast        (Topic#359520)
deeler
Reg: 01-19-20
01-19-20 10:27 AM - Post#2784664
Chevy k2500 6.2D always starts perfectly and runs smooth at idle... problem is that it sometimes dies when letting off accelerator quickly.
It has a new electric pump and new filters. Dont think this is caused by air in diesel.
The car has not been driven for almost four years and given the diesel here i sweden I have added some 2stroke oil when fueling.
Any ideas to try?
Edited by deeler on 01-19-20 10:30 AM. Reason for edit: No reason given.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-26-20 08:05 AM - Post#2785201
    In response to deeler
This should be posted in the truck section. Would get more hits there.
The likely culprit is the injection pump.
That is a mechanical version.
How many miles on it?
Try purging the air and see if it goes away.
there should be a purge valve by the thermostat housing, Put a hose on it and put it in a bottle, run it for a few minutes and close the valve
Old School GM fan FOREVER
Execution time: 0.006 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:09 AM
