Username Post: Oil dipstick tube size?        (Topic#179249)
MT79
Reg: 01-10-08
01-10-08 12:47 PM - Post#1339617
Hi,
I am in the process of putting a remanufactured small block Chevy 350 into a '79 Firebird.
The problem I have is I can't find a dipstick that will fit the block I have. It has a passenger side dipstick, but the two chrome ones I've tried are too big to fit into the block.?? The last one measured 3/8" outside diameter, and was supposed to fit all 350's 1980-1985. What am I missing?
Any help is much appreciated.
PS- the casting number on the block is 1401207. According to that it looks like it is a 1980-85 block, but I can't narrow it down more.
Edited by MT79 on 01-10-08 12:48 PM. Reason for edit: No reason given.
MT79
Reg: 01-10-08
01-13-08 10:51 AM - Post#1341824
    In response to MT79
I should also add that I can't find a timing tab to even come close to fitting. Any ideas ? Could this be a marine block or some other oddball block? any way to tell?
Any guidance much appreciated.
jax1047
Reg: 01-16-19
01-21-19 04:24 PM - Post#2757899
    In response to MT79
I have to same problem with mine I have the same casting number of 14010207. did you find a dipstick for it?
01-21-19 05:11 PM - Post#2757905
    In response to jax1047
Welcome to CT, check the date, this is 10 years old, start a new thread this is the best way.
Execution time: 0.012 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:22 AM
