Username Post: Tail lights and signal lights stay on after I turn switch off        (Topic#363722)
Duke901
Reg: 12-22-20
12-23-20 12:06 AM - Post#2810604
I need some serious advice on finding out why my lights on this 1972 Impala stay on. It has a viper alarm system could this be my problem. I changed the brake switch headlight switch and all the fuses. The lights still stay on it drained my optima battery. Could it be the rust on the frame causing this issue?
12-27-20 09:52 AM - Post#2810831
    In response to Duke901
Welcome CT, if the lites flash when the alarm is set, that could be the issue, it was somewhat common with those alarms.
Edited by Shepherd on 12-27-20 09:52 AM. Reason for edit: No reason given.
Execution time: 0.007 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:18 PM
