Username Post: 74 sbc intake manifold choke plate block off.        (Topic#361302)
imp67ss
Reg: 01-13-13
06-08-20 01:06 PM - Post#2795898
I have a 66 impala with a 70's 350. I wanted to remove the choke plate and put a block off plate. The issue I am having is that there is something holding it on. Has anyone replaced this before? It is right next to the egr. I removed the 2 1/4 tubes. I also have it about 1/4 removed. But something is holding it from the inside. Update I removed the carb, and am just going to get a sabre saw and cut the tubes.
Edited by imp67ss on 06-08-20 02:26 PM. Reason for edit: No reason given.
Execution time: 0.008 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:59 PM
