Username Post: Under-dash A/C plastic cracked - Glue or ??        (Topic#364013)
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
01-17-21 06:22 PM - Post#2812285
Hi All,
One of the plastic pieces for the under-dash HVAC system is cracked. What glue or silicone or RTV or ???? can I use that will withstand both A/C and heater?
Any suggestions or help would be appreciated. Thanks!
    1967 Chevrolet Impala SS convertible 327 - Ermine White C1 - VCCA Senior Award
    1967 Chevrolet Impala SS Sport Coupe 396 - Marina Blue FF - personal "barn-find" lol
Edited by BigDogSS on 01-17-21 07:04 PM. Reason for edit: No reason given.
tooomuch7
Loc: Hartford Ohio
Reg: 03-18-02
01-17-21 06:43 PM - Post#2812287
    In response to BigDogSS
I have some plastic pieces to glue also,I’m going to try Gorilla glue for plastic.
http://www.picturetrail.com/gallery/view?p=999&gid=5387542&uid=2695815&members=1
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
01-18-21 10:36 AM - Post#2812327
    In response to tooomuch7
Here are a couple of pictures.
Attachment: 2021-01-18_10.26.39.jpg (2.28 MB) 3 View(s)
Attachment: 2021-01-18_10.26.47.jpg (3.01 MB) 4 View(s)
tooomuch7
Loc: Hartford Ohio
Reg: 03-18-02
01-20-21 02:53 AM - Post#2812454
Wow,that’s pretty bad.
59fins
Member #212 "20th Year" Gold Supporting Member
59fins
Loc: Surprise Az USA
Reg: 04-07-00
01-22-21 09:58 PM - Post#2812681
How thick is that plastic?
Is it visible?
Can you get to the back side?
Almost looks like the plastic thickness of the defroster piece?
There are shops , body shops that do plastic welding, locating one may be the problem? Watch several demonstrations through the years, does not look hard to do, but it can also be hard not being able to get to the back side.
If it is thicker like the material on foot defuser at floor where heat comes out, or on regular a/c car that tube above defuser where a/c vent tubes are attached.
There are different types of plastic repair materials used to repair plastic bumper covers on newer cars, they are like regular 2 part epoxy, JB weld makes some for small jobs, and comes in different colors, I’ve used their black on cluster housings and a/c vents, on hard plastic tubes, in short, to use any product because you haven’t got a replacement, practice a bit on a different piece. Everything has to be clean, preferably both sides, first application is to hold it together, then work it with thin applications if possible.
The pieces in the pics, at least one of them appears like a repair may have attempted to be repaired before?
Hard to tell what the part is close up, red overspray suggests it’s not in a place that is seen, so your looking for function more than appearance?
Bill H.
67 SS
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
01-25-21 04:34 PM - Post#2812919
    In response to 59fins
Thanks Too and Bill.
Actually, this is from a 1976 T/A I'm helping to restore. The red overspray is actually the reflection from my red toolbox. I cannot get to it from the backside as it is in the middle of the duct. It has not been fixed before. I'd like to at least fix long crack first and see that comes out before tackle that larger chunk that missing. That part in under the center of the dash, at the bottom. The pictures are showing the bottom of the piece and I'm pretty sure it will not be seen.
Harbor Freight sells plastic welder that I'm think about trying.
Edited by BigDogSS on 01-25-21 04:39 PM. Reason for edit: No reason given.
59fins
59fins
Reg: 04-07-00
01-26-21 09:37 AM - Post#2812981
Denis,
Just thinking out loud, the 2 yellow arrows does not need to be fixed? cause it appears maybe some seam sealer was used there at one time?
And the red arrows are the main deal, the big arrow a screw probably goes through? As why is broke in the first place? Guessing..
And if it is where a screw goes through, is it from the top of pic going down? Cause if it is, how long of a screw is it?
The reason I say that, it may be that the screw may draw that together when installed (fingers crossed), put a small washer that would fit the big arrow area? before tightening it up, use do dum dum (3m strip calk sealer) stick it in the crack before you tighten it up, no hard to tell if that is a screw area, and if it is, is there enough to grab it? Once the crack is pulled together the dum dum will cleanup pretty easy. The Yellow arrow areas, not sure if they are supposed to be that way or not ?
When plastic welding, you need to know what kind of plastic it is, and I think the only place you would benefit is the area of the big red arrow, being a novice plastic welder that is if you try that way, practice on something first.... cause it could look worse than the crack ...
Not sure there is a perfect answer here, but if it not seen, I would keep it as simple as possible, once the screw is in place, dum dum could cover the area of the screw as well.
my 2 cents anyways
Attachment: med_1610994987-2021-01-18_10.26.47.jpg (233.33 KB) 3 View(s)
Bill H.
67 SS
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
01-26-21 03:32 PM - Post#2813008
Hi Bill,
Correct, The yellow arrows are just seams, no crack there. I attach another picture from the internet. So it looks like the crack on the piece is facing the interior, which is probably why it is broke. That area (big RED arrow) is a half-circle (mount) that bolts to a bracket. See GREEN Arrow. I want to focus on the crack first (small red arrows), then try to repair the broken mount area (big red arrow).
Is the 3M stuff black? Others have suggested JBWeld. I might be able to clamp it while it dries.
Attachment: TA_duct.jpg (41.96 KB) 3 View(s)
Edited by BigDogSS on 01-26-21 03:58 PM. Reason for edit: No reason given.
59fins
59fins
Reg: 04-07-00
01-26-21 06:57 PM - Post#2813044
Agree, I'd go with the 2 part JB weld black plastic repair, the 3M stuff does not harden, it is a sealer.
Bill H.
67 SS
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
01-28-21 05:47 PM - Post#2813165
I bought the plastic welding, hot air blower at HF, to play with. Fixed ac duct on Br--co, and bumper, on Lin--ln, used the small tip like a soldering iron, cut filler rods out of scrap duct, and bumper.
They asked me, why a Four door, and a Six, and I told them, JUST BECAUSE.
59fins
59fins
Reg: 04-07-00
01-28-21 09:08 PM - Post#2813175
    In response to gcrkfrd
That sounds like a great way to go, and using like material is even a better thought. I have looked at them, but their selection of rods were sketchy, but if you have like material it makes common sense!
Bill H.
67 SS
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
02-02-21 07:14 PM - Post#2813510
It would seem those pieces would be reproduced by one of the Camaro/Firebird, aftermarket parts suppliers. If it's so brittle it's breaking up the way it is, it'll just continue; glue it there, it breaks here, etc. I am Butch/56sedandelivery.
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
02-03-21 02:36 PM - Post#2813557
Good point, Butch. Yes, they do make a reproduction. But believe or not, the piece really is not that brittle. I've "man-handled" with scrubbing and cleaning with no additional issues. I even sanded and painted the molded in metal air deflectors.
With all of that said, if we encounter any additional problems, I will push the issue to buy a new one.
Execution time: 0.011 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:00 PM
