Username Post: coolent recovery system....        (Topic#353086)
vet65b
vet65b
Loc: Albuquerque, NM
Reg: 02-09-06
09-18-18 08:11 PM - Post#2746611
Guys,
Are any of you using a coolant recovery system? If so can you recommend a source for a good one. I have looked at JEGS & Summit and didn't care for what they were offering. Thanks! bill
100 CHEVY
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
09-18-18 08:51 PM - Post#2746615
    In response to vet65b
I use the windshield washer jug on mine.
Mike.
6T5
"2nd Year Gold Supporting Member
6T5
Loc: Asheville, NC
Reg: 07-22-17
09-19-18 04:05 AM - Post#2746626
I thought of doing that when mine started overflowing instead I put a new 15lb radiator cap on and mine is good...
...Ed
1965 Impala SS
Whitetail Hunter
"2nd Year" Platinum Supporting Member
Whitetail Hunter
Loc: Green Bay Wisconsin
Reg: 03-28-15
09-19-18 10:02 AM - Post#2746669
I use a Jack Daniel's whisky bottle. Made a mount ou of a 1 inch wide strip of aluminum with a bend on the bottom to keep bottle from slipping down.Bolted to the core support and hose clamps to hold the bottle. Got a dual valve radiator cap.
vet65b
vet65b
Reg: 02-09-06
09-19-18 05:28 PM - Post#2746711
    In response to Whitetail Hunter
I like whitetalehunter's use of a Jack Daniels bottle, my only problem would be after draining the Jack Daniels bottle I would not remember what I was supposed to do with the empty bottle!
A higher rated pressure cap is probably the way I should go. Thanks! bill
wch
Loc: TX
Reg: 05-13-17
09-29-18 04:26 PM - Post#2747509
Casey
1966 Impala,2dr,283,PG,Wilwood brakes
1985 Chevrolet,C20,350,th400
1986 Chevrolet, Corvette,400ci Dart SHP,TH350
Execution time: 0.02 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:30 AM
