Username Post: Driver's door        (Topic#375759)
MrImpala96
Loc: NE Illinois
Reg: 01-06-18
09-25-24 12:30 PM - Post#2874201
I am, for the most part, unable to get out of the driver's door from inside. From outside, it opens right up. I have the door panel(card) removed, and adjusted the inside handle mechanism back and forth, no change. I tried to adjust the striker and latch, appears to be no adjustment. It looks like the rod that attaches the handle to the latch maybe isn't moving enough, hence why I originally adjusted the handle as far forward as possible.
Let me know if you have any ideas.
Thank you
Kurt
1962 Biscayne 4 door
1996 Impala SS
2015 Dodge Grand Caravan
09-29-24 10:33 AM - Post#2874290
    In response to MrImpala96
sometimes it just needs some grease. spray lithium is my go to. can you pull the rod and open the door?
327
Loc: Ontario , Canada
Reg: 02-09-21
09-29-24 04:04 PM - Post#2874299
    In response to bobb
What bobb said.
61ragtop
Loc: Langley B.C. Canada
Reg: 07-30-03
10-13-24 09:24 AM - Post#2874635
As others have said try some lithium spray grease on the linkage. if its working from the outside I doubt its the striker or latch, most likely the linkage binding or bent. Take the door panel off the pass side and compare?
Execution time: 1.576 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:54 PM
