Username Post: 62 impala transmission swap        (Topic#375415)
Stack
Reg: 07-21-22
07-31-24 09:43 AM - Post#2872253
I have a 62 impala. With a 383 motor and a th350 transmission. My question is. What kind of modification will need to be done to swap out to a 4L80E. Thanks.
dcairns
dcairns
Loc: Orange CA
Reg: 11-07-03
07-31-24 03:54 PM - Post#2872265
    In response to Stack
Are you sure you want the 4L60E or do you mean the 4L60? The E version is for computer controlled.
And are you referring to internal transmission changes or external changes (drive shaft length etc)
- Dave 1964 Impala 4-door sedan.
ss3964spd
ss3964spd
Loc: Fairfax, Va
Reg: 12-21-00
08-01-24 06:25 AM - Post#2872281
Assuming a 4L60 will even fit in the tunnel, at the very least you'd need to relocate/modify the trans cross member, shorten the driveshaft and install a new front yoke on it.
You might consider a 700R4, or even a 200R4, both are more compact than the 4L60. 700R4's are longer than 200R4's, and 200R4's are the same overall length as a short tail shaft TH350.
The 700 and 200 would need to be built to live behind a strong 383, as might the 4L60.
Attachment: Transmission_Dimensions.pdf (1.02 MB) 56 View(s)
Dan
55 Shaker
Loc: north central IL.
Reg: 03-13-06
08-01-24 08:59 AM - Post#2872289
    In response to ss3964spd
STACK said 4L80E. is what he wanted to install.
ss3964spd
ss3964spd
Loc: Fairfax, Va
Reg: 12-21-00
08-01-24 10:49 AM - Post#2872298
    In response to 55 Shaker
Well, ok - but the same challenges of installing a 4L60 apply to the 4L80.
Dan
Teich
Loc: Manitoba Canada
Reg: 10-14-15
08-02-24 06:18 PM - Post#2872344
700r4 will fit, new trans mount shorten front drive shaft, 4L60e needs lots for floor work and if you want to use oem speedometer will need $800.00 tail houseing with speedo drive and signal gen. Then you have lots of "fun" trying to get drive ;;ine to not vibrate. Now have 200r4 in and having a time with vibration. Now 4l80E would be great but too long, I think one peice drive shaft would be nice, lot of work, tried that also would have to lower front of engine to get engine angle of 2.5* then I think it would work Laurie
Execution time: 0.009 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:57 AM
