Username Post: Is This a 327?        (Topic#357210)
07-13-19 12:53 PM - Post#2770611
A very good buddy of mine has this engine for sale. Can anybody decipher what it is? I'm leaning toward buying it if its a 327.
Stamped on engine pad: 18S111983 VO915DR
And which heads are these?
Head casting # 3911032 Date Code: I 13 7
Block date code looks like I 6 7
Block casting # 3914636
Intake casting # 3919803 (Quadrajet manifold)
Intake Date Code F 27 7
The engine looks like its never been disassembled but I can't turn it over with a pry bar on the flywheel. No rods sticking out of the block tho!
I'll post some pictures tomorrow.
junky
Loc: Northeast CT
Reg: 06-27-10
07-13-19 01:30 PM - Post#2770616
Head casting # 3911032 Date Code: I 13 7 =
307/327 CID 1968-70 1.72/1.50
Block casting # 3914636 = 1968-73 307 CID
Intake casting # 3919803 = 327/350 CID 1967-68
4-Brl (Quadrajet manifold)
http://outintheshop.com/faq/casting/castings2 .html
Notes in RED... if it is cheap enough, then you can bore it out to whatever you want it to be. Not being able to turn it with a pry bar, might be the deal killer. Have you tried to remove the plugs, squirting some oil in, and then try to turning it over?
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
07-13-19 04:27 PM - Post#2770625
1968 307 engine
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
07-13-19 04:36 PM - Post#2770626
    In response to dgstarr
It's not a 327. Its missing 20 cubic inches. Good thing you asked.
07-14-19 10:23 AM - Post#2770674
    In response to Tri5man
  • Tri5man Said:
It's not a 327. Its missing 20 cubic inches........
Good thing I asked!! Thanks guys. He wants $200 for it but I'm not gonna bite.
07-14-19 01:03 PM - Post#2770686
Just out of curiosity, how much would the bore need to be enlarged to make a 307 into a 327?
And would the crank and conn rods be the same for 307/327?
cowfarmer350
Reg: 02-03-01
07-15-19 03:44 AM - Post#2770721
It would need to be bored .125 , my 327 in my '62 started out as a 307 , had it sonic tested and came back good to go , so bored it to 4 inch , brought a set of standard 327 cast flat top pistons , i had a set of 1991 corvette l98 heads , already had a mild cam , really perky ,T5 transmission , revs to around 6500 quite easily and good on gas
dcairns
dcairns
Loc: Orange CA
Reg: 11-07-03
07-15-19 12:49 PM - Post#2770754
Or... if you want to get into some machine work.... start with a 327 block and make a 383 out of it
- Dave
1964 Impala 4-door sedan
_________
_/ /___________\ \_
/_________|_________\
|OOO ___________ OOO|
\______|====|______/
|_|------------------|_|
07-16-19 05:55 PM - Post#2770862
    In response to dcairns
Thanks Cowfarmer. I will probably wait for a real 327 instead of making one. Not sure yet.
junky
Loc: Northeast CT
Reg: 06-27-10
07-16-19 06:36 PM - Post#2770864
Why couldn't he make a 383 out of a 283 block?
dcairns
dcairns
Loc: Orange CA
Reg: 11-07-03
07-17-19 06:54 AM - Post#2770897
    In response to junky
I don't know, can you? Are the cylinder walls thick enough for the needed boring?
- Dave
_________
_/ /___________\ \_
del.impala
Loc: delaware
Reg: 04-13-11
07-17-19 07:20 AM - Post#2770901
I wish either one of us was closer. I have a 64 327/250 motor that needs rebuild. I was going to redo it but thats probably not going to happen. Good luck with your search!👍
junky
Loc: Northeast CT
Reg: 06-27-10
07-17-19 07:35 AM - Post#2770902
I did a google search for the question that I asked, and I found the answer in another ChevyTalk forum. Read all about it!!! Link
dcairns
dcairns
Loc: Orange CA
Reg: 11-07-03
07-17-19 08:40 AM - Post#2770904
I saw that myself when I did a quick search earlier. The thread did not seem conclusive. It sounded like you could probably bore it, but the crank clearance might be an issue due to weakness in the block.
I have a 327 engine in my 64 that I had bored/stroked to 383 (line bored with 350 main caps to fit the stroker cranks commonly available), so I know it can be done with a 327 block. And I saw a few mentions of the 283 and 327 castings being the same (within our years of interest here).
It would make a great sleeper having a 283 with an extra 100 cubic inches Of course you would have to make some small compromises in perfectly original appearance, like 2-1/2 inch exhaust and the larger 327/300 radiator. I think there was a 283 variant with a 4 barrel, but probably not sized well for 383.
- Dave
_________
_/ /___________\ \_
Edited by dcairns on 07-17-19 10:12 AM. Reason for edit: No reason given.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
07-17-19 10:55 AM - Post#2770917
I think Speed-O-Motive, for a while, made small journal 383 rotating assemblies. Might have been someone else; it's been a while. Start with a small journal 327, bored .030 over; I can't see a 283 block going .155 over to 4.030 bore. There were a few companies making a 350 from a 283 in the 60's using a welded and reground crank.
I am Butch/56sedandelivery.
07-17-19 07:54 PM - Post#2770949
There was a dual-quad option for 283's back in the day also. Buddy of mine had one for a short time in his '56 Vette. He soon blew the engine!!
Execution time: 0.021 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:03 PM
