Username Post: what ratio is this differential        (Topic#353531)
junky
Loc: Northeast CT
Reg: 06-27-10
10-20-18 05:29 PM - Post#2749133
I picked up a differential, but don't know what the gear ratio is. When I turn yoke 1 3/4 turns, the axle will make one complete revolutions. Can you determine what the gears are from this information? thanks Junky
YOUNG57
Loc: Tennessee
Reg: 12-06-10
10-20-18 09:36 PM - Post#2749148
    In response to junky
“the axle will make one complete revolutions”
Both axles need to turn together to get a good count.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
10-20-18 09:43 PM - Post#2749149
There are factory stamps on the passenger side of the third member stamped into the metal that are tied to the original gear radio(61 to 64’s). There are two letters and numbers, the 2 letters indicate the rear
end ratio.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
Verne_Frantz
Member #574 "61-64 Subject Matter Expert"
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
10-21-18 06:54 AM - Post#2749174
It's probably a 3.55 open rear.
Verne
omarine
omarine
Loc: San Diego
Reg: 06-29-15
10-22-18 07:47 AM - Post#2749237
61 Impala bubbletop, 283, 2bbl Rochester, generator, points and drum brakes- daily driver
'49 Harley Davidson FL - Panhead
Edited by omarine on 10-22-18 07:50 AM. Reason for edit: No reason given.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
10-22-18 11:34 AM - Post#2749249
    In response to YOUNG57
There will be two letters and two numbers stamped into the differential housing, front, right side at about the 9:00 O'clock location
DECEASED
10-22-18 12:48 PM - Post#2749258
Gene is correct about both the probable ratio and the stamping. However, I usually find it easier to determine the ratio by counting shaft revolutions instead of looking for the stamp (which on some cars can be difficult to see or read) and then decoding it.
Jack one rear wheel off the ground and turn it TWO revolutions with the transmission in neutral and the parking brake off. The number of driveshaft revolutions will equal the axle ratio. If the wheel is difficult or impossible to turn, you may have posi. In that case, jack both wheels off the ground and turn either wheel only ONE revolution. Count the driveshaft revolutions the same as for an open rear.
junky
Loc: Northeast CT
Reg: 06-27-10
10-22-18 04:42 PM - Post#2749283
The complete rear is out of the car. I did hold one axle, and turned the driveshaft 1 3/4 turn, for the other axle to make one complete revolution. I did find a stamping and the first letter looks like a partial B second letter is also a B and then the number 2. The second number is illegible. It has a round solid tag at 1 o'clock.
A little paint remover brought up the last digit. It is a 4. There is a big space between the 2 and the 4.
Edited by junky on 10-22-18 05:21 PM. Reason for edit: add additional information
10-22-18 05:29 PM - Post#2749289
If it's exactly 1.75, then it is most likely 3.55.
Verne_Frantz
Verne_Frantz
Reg: 08-22-00
10-22-18 08:39 PM - Post#2749308
I thought I already covered that.
Verne
junky
Loc: Northeast CT
Reg: 06-27-10
10-22-18 09:02 PM - Post#2749311
    In response to Verne_Frantz
The stamped code BB according to the 348-409 website is a 3.36. I will get a picture in the morning. What do the two numbers mean .. they are 2 and 4 or 24?
10-23-18 05:13 AM - Post#2749324
You said, probably, just agreeing with your assessment. Lol
Verne_Frantz
Verne_Frantz
Reg: 08-22-00
10-23-18 05:49 AM - Post#2749326
Besides the two letters to designate the original ratio, there should be 4 numbers: Month 01-12 and day 01-31.
Verne
Member #51
10-23-18 07:17 AM - Post#2749333
If everything is all original, then the solid round tag is the key. It indicates 3.36.
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
10-24-18 11:52 AM - Post#2749437
Junky,
I think you misunderstood Ray. He meant to turn the axle exactly two full revolutions, and count the driveshaft revolutions. Mark your yoke, and mark it again when done. Get it exactly. There isn't much difference between a 3:36 and a 3:56 ratio.
Watch it closely. It will make at least 3 full revolutions before you get close. Then if it goes another 1/3 turn, you have a 3:36. If it goes a half turn, you are looking at a 3:56. A little over 4, and you have a 4:11, and so on.
However many turns you get there is your actual ratio.
This rule of thumb has worked for me since I was a child. That was when dinosaurs still roamed the earth.
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
10-24-18 12:51 PM - Post#2749442
    In response to beagrizzly
If you read he original post he said he just picked up the differential and wanted to know the ratio. No where does it say its currently installed in a car. Doubt all the information about determinating the ratio on a differential installed in a car will answer the OP's question.
Still good information.
Gary
grs
Reg: 07-04-14
10-29-18 11:08 AM - Post#2749884
    In response to Tri5man
Count the number of teeth on the ring gear and the pinion gear. Then you divide the number of the pinion gear into ring gear.
Edited by grs on 10-29-18 12:10 PM. Reason for edit: No reason given.
DECEASED
10-29-18 01:08 PM - Post#2749904
    In response to grs
What if my X-ray vision module is in the shop for annual maintenance, and I don't want (or am not allowed by the owner) to pull the center section?
junky
Loc: Northeast CT
Reg: 06-27-10
10-29-18 03:06 PM - Post#2749922
for a little clarity, here are the pictures of the spare differential that I asked about originally.
Based on your chart above, this is a 3:36 differential.
This is where it gets a little weird, since the differential in my car has the same BB stamping, but the tag has a second hole in it, which would designate that it is a 3:55.
This is the date code on my differential.
And here is the tag picture.
Edited by junky on 10-29-18 03:09 PM. Reason for edit: No reason given.
A White Sport Coupe
A White Sport Coupe
Reg: 08-19-10
11-07-18 02:13 PM - Post#2750682
Hello,
The tooth count is stamped on the ring gear. Divide the large number by the small number.
Bob
Member #51
11-07-18 03:11 PM - Post#2750686
    In response to A White Sport Coupe
  • A White Sport Coupe Said:
Hello,
It's also stamped on the end of all Chevy pinion gears like this.
10-37-GM = 3.70 ratio
Execution time: 0.027 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:20 PM
