Username Post: Holley Sniper        (Topic#365745)
Hrm2k
Platinum Supporting Member
Hrm2k
Loc: Baltimore county MD
Reg: 07-05-21
07-07-21 08:48 AM - Post#2822796
New guy here. I recently installed a Holley Sniper units on my mid engine V8 Corvair. It was a complete kit with great instructions. It fired first try and has really added a huge amount of torque in the low end. I'm using a TH425 transaxle from a 73 el Dorado with a 3000 stall convertor. I have a couple of hundred miles on it and It was well worth the price
Attachment: IMG_4166.JPG (1 MB) 3 View(s)
Attachment: IMG_4143.JPG (978.03 KB) 2 View(s)
65 V8 Corvair
64 Cadillac Survivor
1917 Ford Roadster Pick Up
Edited by Hrm2k on 07-07-21 08:50 AM. Reason for edit: No reason given.
steve65
steve65
Loc: New Westminster BC
Reg: 09-25-13
07-07-21 09:58 AM - Post#2822799
    In response to Hrm2k
Welcome to the site.
I gotta say that's the first time I have ever heard of that conversion. Very impressive indeed. I bet it goes like a bat out of hell too!
Steve
Steve Duncan
66 Impala 2dr Coupe
Not sure of color yet
work in progress
Hrm2k
Hrm2k
Reg: 07-05-21
07-07-21 10:31 AM - Post#2822800
    In response to steve65
Thanks Steve
We took out a bunch of weight but added frame connectors….haven’t weighed it yet …figuring around 3,000 lbs.
Still a lot of fun
65 V8 Corvair
Edited by Hrm2k on 07-07-21 10:31 AM. Reason for edit: No reason given.
Member #409
07-07-21 06:43 PM - Post#2822829
How about some photos of the conversion?
Hrm2k
Hrm2k
Reg: 07-05-21
07-08-21 03:37 AM - Post#2822838
    In response to Rick_L
Attachment: no_guts.jpg (114.4 KB) 2 View(s)
point of no return
Attachment: gn4.jpg (98.19 KB) 2 View(s)
Attachment: mufflers.jpg (125.87 KB) 2 View(s)
65 V8 Corvair
Edited by Hrm2k on 07-08-21 03:41 AM. Reason for edit: No reason given.
Hrm2k
Hrm2k
Reg: 07-05-21
07-08-21 03:48 AM - Post#2822839
TOP PHOTO
The Corvair was a running / driving car when the beer hit. Things changed a lot.
MIDDLE PICTURE
While the front motor mount is visible, you can also see the pumpkin ( rear end attached to the transmission ) along side the engine. The piece of metal above the carb is the track to hold the back window in place
BOTTOM PICTURE
The exhaust system. Everything is mounted solid.
We had to make a tunnel in the oil pan for the right side axle and flange
Engine compartment
Attachment: oil_pan.JPG (51.64 KB) 2 View(s)
Attachment: under_glass.jpg (42.8 KB) 4 View(s)
65 V8 Corvair
Edited by Hrm2k on 07-08-21 03:57 AM. Reason for edit: No reason given.
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
07-08-21 05:24 AM - Post#2822845
Nice job on the conversion. I have a Holley Sniper unit on the crate 350 in my 1930 DeSoto. It does increase low end torque as you stated and start up is immediate.
Attachment: 30Desoto001G.jpg (68.34 KB) 5 View(s)
Vern
1930 DeSoto Business Coupe- 350 Chevy V8, EFI, 4-wheel disc brakes, Wire Wheels, TH400, S-10 Rear, A/C
Rick Dorion
Rick Dorion
Loc: Accord, NY
Reg: 09-21-12
07-10-21 02:21 AM - Post#2822961
I love the V8 conversion Corvairs. Kudos to you. That car must be so much fun.
1967 Belair - LM7 5.3, Autogear M23Z, Global West, C5 brakes and rims.
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
07-10-21 09:55 PM - Post#2823023
    In response to Rick Dorion
Please describe your trans set-up.
425 Transaxle...BOP adapter?
Then did you use the Eldo's suspensiion, brakes and etc. Or, did you graft it in to the Corvair? If so, how?
Hrm2k
Hrm2k
Reg: 07-05-21
07-12-21 01:06 PM - Post#2823117
    In response to Stinky
BOP adaptor was to attach the SBC to the TH425 belhousing.
The Caddy drive line ended at the flanges on the pumpkin and the ride side axle flange.
We used the Corvair Trailing arm but no other Corvair pieces. The axles are 10 5/16 inches long with the bolt on Caddy flange on one end and a Corvair U joint on the other.
THe toe in / toe out control arm bolts to the main cross member. A control arm bracket controls the camber in and out. QA 1 coil springs with 450 lb springs complete the suspension. The coil overs bolt through the plated frame rails.
We used an old Corvette drag racing trick where the trailing arms bolt to the body. We machined aluminum bushings so the suspension only goes up and down......no twist
The bottom suspension photo shows the toe control arm. There is a second bar that did not work as we thought it would so it was removed and a traditional style control arm bracket was fabricated. You can see most of the susopensin in that photo
Attachment: axle_3.JPG (46.42 KB) 2 View(s)
this is one of the axles
Attachment: suspension.jpg (105.89 KB) 2 View(s)
65 V8 Corvair
Edited by Hrm2k on 07-12-21 01:15 PM. Reason for edit: No reason given.
5Larry7
"18th Year" Gold Supporting Member
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
07-13-21 10:55 AM - Post#2823159
I built a Toronado Corvair in the 90's using the 455 Olds engine and a 67 TH 425 trans which had a switch pitch torque converter. Unfortunately just a few months after I finished it, the car was involved in a chain accident and was eventually totaled. Your car looks great and I wish you many miles of enjoyment.
WagonCrazy
WagonCrazy
Reg: 06-07-05
07-23-21 05:29 AM - Post#2823749
    In response to 5Larry7
Very impressive conversion! Nice job explaining what you've done too.
Just a guess but are you running an extra quart or 2 of oil to compensate for the amount that is constantly trapped in the front of the engine (due to that pan modification)?
Edited by WagonCrazy on 07-23-21 05:30 AM. Reason for edit: No reason given.
Hrm2k
Hrm2k
Reg: 07-05-21
07-29-21 04:05 AM - Post#2824089
    In response to WagonCrazy
I'm running a remote oil filter. With the extra lines, I'm guessing probably an additional pint or two in the lines.
The area between the pan sump and the tunnel holds about a pint of oil so it should be a wash.
At some point, I might just plum a line from the dead spot back into the sump.
65 V8 Corvair
Execution time: 0.009 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:09 AM
