Username Post: distributor for 950c upgrade to HP        (Topic#357421)
86 406
Reg: 06-10-12
07-28-19 02:26 PM - Post#2771825
Hi, I would like to upgrade from a 950c to the HP ecu. I was using a Msd distributor pn. 8366. will this work with the HP unit? If not, will the Holley dual sync dist. # 565-200 be what I need? Thanks for your time.
07-28-19 04:56 PM - Post#2771846
    In response to 86 406
It should work.
The dual sync would be a better choice because you
could utilize the sequential feature in HP. The dual sync also has Hall effect sensors which are recommended by Holley - more robust and reliable.
If you were to ask this on the Holley EFI forum, you would get a more detailed discussion.
Execution time: 0.016 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:06 PM
