Username Post: Oil pressure sender 03 Avalanche        (Topic#366482)
Crusty66
Crusty66
Loc: Albany, eNZed
Reg: 11-04-12
09-22-21 11:39 AM - Post#2827697
Hi, on an LM7 5.3, how do you change the oil pressure sender? does the inlet manifold need to be removed? I can't get my hand down to where it is at the back of the block.
Steve
1966 Caprice 396 496 496mkII TH400
'03 Avalanche 1500 RHD
Senior Moderator
09-23-21 05:01 AM - Post#2827757
    In response to Crusty66
You can get back there without taking anything apart other than the plastic cover, it's just not fun. A socket, extension, and maybe a u-joint will help. You're working mostly by braille, and you'll scratch your hand and wrist up for sure. I did one on my wife's truck (06 Silverado 6.0) not long ago.
Crusty66
Crusty66
Loc: Albany, eNZed
Reg: 11-04-12
09-23-21 01:52 PM - Post#2827813
    In response to someotherguy
Thanks Richard. I'll give it a go!
Mine is further complicated by being a right hand drive conversion, so the A/C hoses are swapped to the left side near where the pcv valve is - about where my hand will be going!
Steve
Senior Moderator
09-23-21 03:16 PM - Post#2827823
Yeah; all bets are off for "standard procedure" when you have a modification that major! Best of luck and let us know how you do with it. At least I can verify the job is possible as I described on a normal production LHD model as I've done it myself fairly recently.
It will probably at least give you some visual reference to look at pictures on the web of the sensor's location and the harness clip design so you can correlate that to feel once you start reaching down in there. There are also a number of write-ups on doing the job but it may vary a bit from year to year and also generation (the 2007-up trucks have it in the same spot but accessories and bracketry may pose somewhat different obstacles.)
gkralik3645
gkralik3645
Loc: omaha
Reg: 12-05-13
09-25-21 06:05 AM - Post#2827924
From experience, go to youtube and watch someone else do it a couple of times before you try it. It is not an easy task.
Also I would suggest you get something thick, like a small rug or maybe some thick cardboard to lay on the top of the engine, so that you can lay on it yourself as you reach clear back to the rear of the engine to get to it. Make sure the engine is cool since you will more than likely be laying on it and don't want to burn your stomach.
George
Crusty66
Crusty66
Loc: Albany, eNZed
Reg: 11-04-12
09-25-21 03:51 PM - Post#2827949
    In response to gkralik3645
Well, I got into it and it was really quite easy. Only a couple of bits of skin missing
Had to go and buy an 1 1/16" deep socket, but took less than 1/2 hour to do.
Steve
Execution time: 0.008 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:04 AM
