Username Post: Service Air Bag        (Topic#365507)
Cattoyboy
Loc: Hayward, WI
Reg: 01-01-12
06-13-21 11:54 AM - Post#2821569
This warning came on for the drivers side. What's that all about ??
05 Silverado
Edited by Cattoyboy on 06-13-21 04:23 PM. Reason for edit: No reason given.
06-13-21 04:35 PM - Post#2821574
    In response to Cattoyboy
To properly diagnose this the Sirs functions must be scanned for fault codes, a normal Obd scanner will not access this info. You must be careful doing any work on Air Bags.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
06-15-21 05:19 PM - Post#2821652
Extremely likely the failure is the impact sensor. Located under the radiator. Have probably changed 100 of them. Is accessed from under the truck. 1 torx bolt.
Worth noting that threads are reverse
Old School GM fan FOREVER
Edited by rockfangd on 06-15-21 05:20 PM. Reason for edit: No reason given.
Senior Moderator
06-18-21 07:53 AM - Post#2821759
    In response to rockfangd
Good info; any recommended diag procedure before shotgunning it? That sucker is nearly $200.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
06-18-21 06:47 PM - Post#2821782
    In response to someotherguy
IIRC Dorman makes them. But I go with OEM as I find Dorman parts seem to have a 1 year life span.
If Code relates to driver side impact sensor, or related I would go for that.
Having the code would help to pinpoint it
I have seen so many swell, split in half, corrode. Especially in the winter. They must get water inside and when it freezes it splits
Rockauto has it for 115. WVE brand
Part # 5S13674 for regular cab or extended cab but not crew cab.
Edited by rockfangd on 06-18-21 06:53 PM. Reason for edit: No reason given.
Cattoyboy
Loc: Hayward, WI
Reg: 01-01-12
06-19-21 04:22 AM - Post#2821788
It is indeed the front driver side sensor. $230
Neighbor owns a body shop and has one ordered. From who?? Should be in and installed by Tuesday.
Thanks for the response.
Execution time: 0.012 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:39 AM
