Username Post: No Start then Start?        (Topic#356634)
Ray1
Reg: 12-05-03
06-01-19 10:48 PM - Post#2767518
Tried a few times to start the 04 Silverado 1500 today and got nothing at all, then a few minutes later it started perfectly, and has been fine since. I had a similar problem with my car which turned out to be a bad starter relay. Random non-starts until it completely failed. I'd like to go ahead and replace the starter relay and whatever else could be causing the problem. I'm looking at this part on RockAuto - Link. At $6.92, I'm thinking this is a general relay and not the starter relay. The one for my car was around $50. What part do I need, and where can I get it?
If there's another source for my problem, I'm all ears.
Senior Moderator
06-02-19 04:44 AM - Post#2767527
    In response to Ray1
Locate the starter relay in your electrical center using the legend inside the lid, or if missing, in your manual. The relay is very likely the same as several others in there. It isn't literally the relay for all the current to the starter; that's the starter solenoid's job. Anyway you can swap another relay in place before spending money on a new one and waiting for it to arrive. My suspicion is that the relay is probably fine, but you could rule it out that way. Most likely suspects are the starter going bad or ignition switch, but those are obviously more expensive and more labor.
06-02-19 08:06 AM - Post#2767534
    In response to someotherguy
Check your ground wire from the battery. We had a Tahoe at the shop that did something similar and it was corrosion under the ground cable that went to the block. It started fine and then it didn’t even crank. I don’t know if it was intermittent because I looked for a problem right away. One clue I got was when we hot shot it because my original thought was it was a low battery. It started fine with a hot shot, but only when the ground from the jump box was hooked to the aluminum bracket on the engine. It acted the same with the ground on the battery. You could have just enough corrosion to be causing an intermittent problem, or maybe condensation making you lose ground and later it dries up and you get better contact.
1957 Cameo Carrier
Jeff Dodson
Jeff Dodson
Loc: Lake Jackson, Tx. U S A
Reg: 09-30-04
06-05-19 10:39 AM - Post#2767759
    In response to wagonman100
Perfect. I am having g the same issue on my 04 Silverado
2004 Chevy Silverado crewcab
2010 Harley Davidson Electraglide
Ray1
Reg: 12-05-03
06-06-19 10:23 AM - Post#2767836
The parking lamp relay looks like it is the same thing, I'll swap that.
I can see it being the ignition switch and have been planning to replace that for a while.
Ray1
Reg: 12-05-03
06-06-19 10:30 AM - Post#2767838
The block? I've tried tracing the ground back and I lost it at the rear of the oil pan, passenger side. Or I'm looking at something else. I've got the "this can't be right" feeling, so I came in to check.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
06-06-19 01:47 PM - Post#2767844
    In response to Ray1
Sounds like you are looking for G102 and the attach point for the negative battery cable. Two locations. If it is a V8, then look for the ground wire attached to the left side of the block, below #6 spark plug. If it is a 4.3L then it is located on the front right side of the block near the lower portion of the head/block area.
Ray1
Reg: 12-05-03
06-06-19 05:38 PM - Post#2767856
    In response to george88gta
It's the 4.8.
I'm looking at a firing order diagram here, just to be sure I have the right "left-"
Link
So the negative cable crosses under the engine and attaches to the opposite side of the block?
Ray1
Reg: 12-05-03
06-06-19 05:40 PM - Post#2767857
    In response to Ray1
My relays are glued in good, probably with mouse urine. Not sure how I'm going to get them out without breaking them.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
06-07-19 02:56 AM - Post#2767869
    In response to Ray1
  • Ray1 Said:
It's the 4.8.
Link
Sorry, I got it backwards. The ground is on the drivers side ( left side) under the #5 plug. It is down near where the pan/block meet. Also check the grounds at the back of the heads. Damn old age creeping in!
Edited by george88gta on 06-07-19 03:07 AM. Reason for edit: No reason given.
Ray1
Reg: 12-05-03
06-12-19 10:09 PM - Post#2768354
No problem, I can honestly say I'm getting older too. I did spend some time looking for the ground on the passenger side though - I suppose that is the starter motor I was looking at? I was questioning the sanity of the GM engineer who put the ground above the starter motor. After pulling the HVAC door actuators, I'll believe GM would put anything anywhere, as long as it was hard to get at.
Ray1
Reg: 12-05-03
06-13-19 08:20 PM - Post#2768416
    In response to Ray1
Found the ground. Is there a better way to get at it than feeling around from the top? I don't see one.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
06-14-19 06:44 AM - Post#2768442
    In response to Ray1
I would try loosening the plastic wheel well shield, to gain some clearance. Definitely in a fun spot.
Edited by george88gta on 06-14-19 06:46 AM. Reason for edit: No reason given.
Smitty_Chevy
Smitty_Chevy
Loc: Hampton, GA
Reg: 10-29-08
06-14-19 02:16 PM - Post#2768470
    In response to Ray1
Relay puller pliers are your friend.
The tree of liberty must be refreshed from time to time by the blood of patriots and tyrants - Thomas Jefferson
Execution time: 0.018 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:36 PM
