Username Post: underseat rubber mat        (Topic#351699)
rod
Loc: kingman,az
Reg: 04-29-00
06-23-18 07:09 PM - Post#2738006
does anyone make a replacement for the rear underseat rubber mat?
if not, what have you done for something to cover the metal floor?
thanks Rod in AZ
gundog55
gundog55
Loc: Northern Indiana
Reg: 09-26-11
06-25-18 04:37 AM - Post#2738103
    In response to rod
Ciadella Interiors
1955 Two Door Post,400 SBC, 400 Turbo, Dana 60 W/456 Gears. 1955 Nomad, 355 SBC, 400 Turbo, 12 Bolt W/410 Gears.
DRIVE IT LIKE YOU STOLE IT!
cdmhenry
cdmhenry
Loc: Minden, NV.
Reg: 09-14-00
01-08-20 06:53 AM - Post#2783974
    In response to rod
Just a FYI. Each year of rear underseat mat had a different texture, plus Chevrolet offered a replacement mat until around 1960 which had a different texture than those originally installed. So there were four textures used by Chevrolet.
The reproduction mat that was offered (not sure it's still available) wasn't as long, front to back, as the originals. Originals went down onto the rear seat well vertical surface and up onto the vertical surface between the cargo deck and underseat floor.
Every Government Interference In The Economy Consists Of Giving Unearned Benefit, Extorted By Force, To Some People At The Expense Of Others - Ayn Rand
Execution time: 0.426 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:59 AM
