Ron Surf
Reg: 02-23-17
07-06-24 05:11 PM - Post#2871527
Just got my ‘58 Impala back from the shop. Had the carb rebuilt, new fuel pump, cleaned fuel tank and fuel lines. I let the car warm up for a few minutes, but then it tends to stall when I put it in reverse to get out of the garage. I’ll start it up again, and it might stall when I get to the closest stop sign. Once I pull over and start it again and let it warm up more it is better, but still feels like it might stall if I don’t give it some gas at stops. Eventually it runs fine and I have no issues. Do I need to let it warm up longer when I start it, or do I need to go back to the shop and have them adjust things?
49_Purple
Loc: Krydor, Sask. Canada
Reg: 08-21-15
07-06-24 11:18 PM - Post#2871536
In response to Ron Surf
Kinda sounds like the idle speed is too low and possibly the mixture screws set on the lean side. If the choke is not fully closed at initial cold start then it can act like that also. If you don't know how to adjust the carb yourself then best take it back to them and have them start it when cold to adjust things. It is very simple to do once you know how.
58 Impala Sport Coupe 348 tripower
58 Impala Convertible 348 tripower
58 Sedan Delivery 348
65 Pont Custom Sport
66 Toronado
49 Chev 5window diesel
76 Sierra Classic 454
82 Corvette
84 Corvette
93 Corvette
95 Camaro Z28 Conv. |
GreatNorthWoods
Reg: 03-31-02
07-07-24 02:50 AM - Post#2871538
In response to 49_Purple
I agree. Sounds like the automatic choke is out of adjustment.
Vern
1930 DeSoto CK Business Coupe- 350 Chevy Crate V8, 4-wheel disc brakes, TH400, S-10 Rear, Heidt's IFS, A/C |
japete92
Loc: No. Virginia
Reg: 01-18-13
07-07-24 07:12 AM - Post#2871542
As others have said; auto choke is a likely candidate.
Check the initial timing both with, and without, vacuum advance before futzing with the carb.
If it's a 'points' ignition, check/set dwell first, then timing, then carb.
Pete
Ron Surf
Reg: 02-23-17
07-07-24 10:27 AM - Post#2871550
Thanks for the advice. I think I will call the mechanic Monday and make plans to take it in.
Ron Surf
Reg: 02-23-17
07-07-24 10:28 AM - Post#2871551
In response to japete92
Thank you. Going to discuss with mechanic on Monday.
1958Belairjoe
Loc: FL
Reg: 08-03-23
07-16-24 03:48 PM - Post#2871842
well how did you make out so far with the stalling
