Username Post: Cpp 500/600 on a 348 58 impala        (Topic#358664)
Meyer
Reg: 11-01-19
11-01-19 04:12 AM - Post#2779275
They only offers a kit for a smallblock...
Has anyone done this ?
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
11-01-19 06:28 AM - Post#2779287
    In response to Meyer
Johnny, I replied to your PM.
A modern pump can be installed on an original 58 348 with the brackets for a 60-61 348. However, the block must be drilled and tapped for the bolts, and the balancer/pulleys must be changed. If you are unsure if your engine is original, check the stamping on the pad in front of the pass head.
Jalapeno
Edited by Jalapeno on 11-01-19 06:29 AM. Reason for edit: No reason given.
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
11-01-19 09:43 AM - Post#2779305
    In response to Jalapeno
How about n electric pump off an Volvo? Several others there as well.
Ebay has them very reasonable. Pick a part?
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
Hobart
Hobart
Loc: Chicago, IL USA
Reg: 11-18-02
11-02-19 05:19 PM - Post#2779403
On my 1958 Delray I have the CPP500 box (thanks to Jalapeno) and the engine is a 1959 348.I had to drill & tap the block, as mentioned; but it was easy. I used the Show Cars #6640 bracket kit. The clearance between the pump-pulley and the gearbox is super-close, but it works. I was able to use my stock (1959) balancer. I also have aftermarket A/C, which is why I have the extra crank pulley. The pulleys I used were: GM Crank pulleys: 6-3/4”, 2-groove #3744043BA; 1-groove #3751232. P/S pulley: 2 groove from LGC #3941107. W/P pulley: 2-groove chrome from LGC. I don't recall what P/S pump I used, but I think it was from a 1969 small-block Chevelle. The P/S belt I use is a #15350, which just squeezes on and limits the travel of the pump so it doesn't hit the box.
Bill
Chicago Gearheads Car Club / Lynch Mob Racing
'59 Bel Air 2dr sedan
'68 Chevy II Nova
'72 Eldorado ragtop
'80 Z28
Edited by Hobart on 11-02-19 05:25 PM. Reason for edit: No reason given.
Meyer
Reg: 11-01-19
11-03-19 12:51 PM - Post#2779462
    In response to Hobart
Thanks to all
ragtp66
Reg: 12-09-07
11-07-19 05:44 PM - Post#2779748
Jalapeno,
Do you have any experience with the Borgeson box?
I am considering doing this swap on a 61 Parkwood a buddy and I are building
https://www.summitracing.com/parts/brg-999015/?tab ...
Chris
Toys:
1987 Sea Ray Pachanga 22
Jalapeno
Jalapeno
Reg: 04-30-00
11-08-19 08:17 AM - Post#2779773
    In response to ragtp66
I have not, Chris. Others here have, though, and hopefully will give y'all the lowdown.
Read the reviews in your link. 2 reviews, looks like both from the same guy.
Jalapeno
ragtp66
Reg: 12-09-07
11-12-19 06:48 PM - Post#2780076
I was hoping someone here would have been down the road. Borgeson claims that it goes in without needing to modify the radiator or the ps pump. Never know what the reviewers setup is so I take that with a grain of salt. I may still go that route as I have NEVER had an issue with Summit not taking something back and getting a full refund. The stock assist system is just not the greatest and i just wanted another option. Especially since the wagon is getting big wheels and bags.
Toys:
Hobart
Hobart
Reg: 11-18-02
11-12-19 07:11 PM - Post#2780079
Chris, try searching "Global West bump steer ", as I believe that system uses the Borgeson / Delphi 600 box; and I know I've seen posts about that system - maybe that will give you some leads. I have one for my `59, but I haven't installed it yet.
Bill
'68 Chevy II Nova
'72 Eldorado ragtop
'80 Z28
Execution time: 0.022 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:49 AM
