Danchuk
Username Post: Problems with cast-iron powerglide        (Topic#364694)
carolinakid
carolinakid
Loc: Erwin NC
Reg: 08-27-03
03-24-21 03:50 PM - Post#2816724
Having problems putting my gear shifter in park with a cast iron powerglide. What area should I look at for the cause of this problem. Thanks
drtyler
Loc: Georgia
Reg: 05-06-10
03-24-21 05:49 PM - Post#2816729
    In response to carolinakid
I would try adjusting the shift linkage.
See bottom of this page (and it continues on the following page):
http://chevy.oldcarmanualproject.com/shop/1955/55c...
Jalapeno
Member #252
Loc: The Republic of Texas
Reg: 04-30-00
03-24-21 06:56 PM - Post#2816732
Maybe the trans mounts, look to see if one or both have the rubber separating from the metal core. Many aftermarket mounts are cheaply made and do not last long.
Try lifting the PG with a floor jack and see if that changes the shifting effort.
Jalapeno
carolinakid
carolinakid
Loc: Erwin NC
Reg: 08-27-03
03-28-21 02:17 AM - Post#2816968
    In response to Jalapeno
Thank you all
57210sportsedan
Loc: Germany / Georgia (US)
Reg: 02-06-03
06-15-21 04:03 AM - Post#2821616
Did this work out? I had the exact same problem and it was (thankfully) just sagging (new) tranny mounts. Seems even a tiny drop can cause a big scare.
Markus
57 Chevy 210 Sport Sedan
70 Triumph Spitfire
bought and sold a few more ...
Execution time: 0.006 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:11 AM
