Username Post: 57 turn signal wires        (Topic#363977)
Mdm57
Reg: 12-17-18
01-14-21 12:43 PM - Post#2812068
im trying to replace the wires--- anyone know how to get the connector apart where the wires come together under the dash---looks like it should just pull apart but wont---is it just hard to get apart or is there a method to use i dont want to break the connector
01-14-21 08:13 PM - Post#2812106
    In response to Mdm57
It just pulls apart, but if any of the terminals had a bad connection, it could have caused the terminal to heat up and melt the connector together. Try gripping both connectors with pliers and wiggling them and see if that breaks them loose.
FYI: The male terminals are held in the plastic connector by the tip on one side. Squeeze the terminal together, so you can pull the wire out of the connector.
https://www.delcity.net/images/photos/225px/9 29895...
Execution time: 0.007 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:20 AM
