apix17
Loc: San Francisco Area
Reg: 12-22-07
10-08-20 08:02 PM - Post#2805135
I have my 55 Belair 3 speed manual transmission with overdrive removed for clutch work. I have been chasing a vibration for quite some time that happens about 55 mph and above. Because of what I have ruled out I suspect the vibration may be coming from the transmission. I have no transmission experience. I am asking for advice from those who may be familiar with this tranny as to what i can check in the tranny that may be causing the vibration while it is out. Your input appreciated. Thanks
55MAS
Loc: North Coast, USA
Reg: 12-19-01
10-09-20 04:00 AM - Post#2805141
In response to apix17
Before the transmission. Have you verified that the pilot bushing in the crank is not worn oversize at the bore? Have you verified that the universal joints have no play?
10-09-20 06:02 AM - Post#2805149
Does the vibration go away when you let off the gas or push in the clutch? It's not very likely that the transmission will cause a vibration.
apix17
Reg: 12-22-07
10-09-20 10:28 AM - Post#2805159
In response to acardon
A little about my vibration. I installed new u joints and have had the driveshaft balanced. I installed new motor mounts. Vibrates in or out of overdrive while accelerating or coasting or maintaining speed Clutch in or out makes no difference. Have tried shutting engine off at about 65 mph no difference. Transmission in second or third makes no difference. Put new balanced tires on no change. Also checked run out of tires.Also checked for correct angles between engine driveshaft and rear end. Front end in good shape no play. I have owned the car about four years has done it since I got it.I have not checked pilot bearing but will. Thanks for your comments any other comments appreciated.
Edited by apix17 on 10-09-20 11:45 AM. Reason for edit: No reason given.
10-09-20 12:45 PM - Post#2805163
Is the differential open or posi traction? With the rear end jacked up, can you feel any roughness when manually rotating the tires? Any noise from rear end?
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
10-09-20 02:16 PM - Post#2805171
Could just be that the Ujoints are out of phase
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
apix17
Reg: 12-22-07
10-09-20 05:06 PM - Post#2805179
Car is presently up on jacks I just rotated rear wheels seems smooth and quiet. It is not a positraction rear end probably the stock 4:11 rear end that I believe came with the overdrive cars.
10-11-20 09:43 AM - Post#2805256
i would put the car on jackstands and rotate the driveshaft to see if there is any runout. are your wheels hubcentric?
Red56trk
Loc: Seal Beach, CA
Reg: 04-23-20
11-03-20 08:57 AM - Post#2806927
In response to bobb
You may have a worn rear bushing in the transmission and also some wear on the driveshaft front yoke. It should also leak oil from the rear seal as a result.
56sedandelivery
Gold Supporting Member
Loc: Everett, Wa.
Reg: 02-26-08
11-03-20 04:31 PM - Post#2806946
In response to Red56trk
If the vibration is't occurring ALL the time, but only AFTER reaching 55 MPH, then you have an issue other than in the drive-train, possibly tire/wheel balance or front end issues. Even with multiple attempts at wheel balancing, that's where I would still look; if you've already had this done, then have it redone elsewhere. JMO.
I am Butch/56sedandelivery.
apix17
Reg: 12-22-07
11-04-20 06:48 PM - Post#2807003
Thanks so much for your inputs I have checked the driveshaft yoke for wear and seems to be ok the yoke diameter is okay and not much play when engaged in the transmission output shaft Butch I am going to pursue your thoughts on the possible tire problem. I have put on new tires but I would like to install maybe borrow a known good set of mounted tires to see what happens.Will keep you guys posted.Thanks again
Mel Foye
Reg: 09-29-00
11-11-20 04:53 PM - Post#2807517
Well apix17 what have you come up with? Any place that does a spinning balance check while on the car?
I don't know if a weight came off of a brake drum if you could feel it?
apix17
Reg: 12-22-07
11-11-20 05:56 PM - Post#2807528
In response to Mel Foye
Mel I have not pursued the problem any further. I presently have the car in my garage replacing all the clutch linkage. Next project is vibration. Thanks for your interest.Will update you when I have some new information.
toms57
Loc: Caney, Ks, USA
Reg: 10-28-01
11-11-20 07:00 PM - Post#2807534
I had a harmonics type vibration at higher speeds that was cured by finding a tire shop that took extra time with my car. Moved all wheel weights around and put them in the center of the wheel rather than clipped to the outer edge of the wheel. It made a world of difference for mine.
Toms57
