Username Post: Speedometer doesn't work 57        (Topic#359051)
J REID
J REID
Loc: SW Minnesota
Reg: 04-09-04
12-06-19 01:49 PM - Post#2781601
After driving without a speedometer for a year I checked into it & found out the brand new $85 speedometer cables plastic tip had twisted off in the speedometer. My first thought was to remove the instrument panel but after looking at it I don't know. I was hoping that someone could guide me in the right direction on getting it out. If & when I do get it out, I plan on lubricating it according to the great article on top. Thanks in advance for any help
57 210 4dr, 57 2dr ht project, 67 Chevelle SS project, 40 Chev coup project
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
12-06-19 02:16 PM - Post#2781603
    In response to J REID
the instrument panel will have to come out. seems like your speedo is locked up. once it is out you can see if it will turn by hand.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
15 chevy equinox
J REID
J REID
Loc: SW Minnesota
Reg: 04-09-04
12-07-19 08:34 AM - Post#2781647
    In response to 62chevy427
I positioned a replacement cable end into the hole & to my way of thinking it did turn hard but was wondering if it could have been partly because the plastic was pushing against the back? The speedometer worked fine until the old one twisted off by the trans because I didn't tighten it properly when I put it together 10-12 years ago. Just trying to figure out the best way of getting it out to work on it.
ThumperNZ
ThumperNZ
Loc: New Plymouth, New Zealand
Reg: 07-08-07
12-07-19 01:12 PM - Post#2781664
If the cable end is plastic, then it's the wrong one if the speedometer is a stock type. All TriFives used metal cables.
'57 Model 1037D COMPLETED! (but are they really?
J REID
J REID
Loc: SW Minnesota
Reg: 04-09-04
12-07-19 02:00 PM - Post#2781667
    In response to ThumperNZ
It was a replacement bought from one of the sponsors. I didn't like it either but put it in & learned the real hard way. Still trying to figure out the easiest way to get the thing out.
Mel Foye
*VIP* Founding Member
Mel Foye
Reg: 09-29-00
12-07-19 03:28 PM - Post#2781675
The guys that really know will give you a better answer but till they check in try a Q TIP with a little chassis grease on the end and go slow. Mel
Mel Foye
Mel Foye
Reg: 09-29-00
12-08-19 03:52 PM - Post#2781728
To 62chevy427 and ThumperNZ. I read my post and it reads as if the===experts==== are other than you two. That was NOT my intent. Since there had been no ideas given how to get the tip out w/o pulling the cluster I suggested the greased Q tip. I tried to be a little funny about my shade tree approach but I gave an impression that was counter to what I think. Sorry. Mel
J REID
J REID
Loc: SW Minnesota
Reg: 04-09-04
12-09-19 09:56 AM - Post#2781782
    In response to Mel Foye
Got me thinking down a different track. I have something else in mind but it is very hard to get into that spot. I am thinking that when it twisted off it wasn't clean, so ?? Thanks for the idea
Execution time: 0.02 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:51 PM
