Username Post: fuel pumps for 2Bbl vs 4 Bbl carb set up        (Topic#356477)
55nomad
Member #742 "17th Year" Gold Supporting Member
55nomad
Loc: Spring, Tx
Reg: 12-27-02
05-19-19 07:38 AM - Post#2766707
Are the 283 fuel pumps the same for the 2Bbl and 4Bbl carb? I'm converting my 2Bbl carb system to 4Bbl. Also, I believe the fuel lines from the tank are larger for the 4Bbl Carb, correct?
Tom
YOUNG57
Loc: Tennessee
Reg: 12-06-10
05-19-19 08:32 AM - Post#2766711
    In response to 55nomad
No
The fuel pumps and 5/16” fuel lines were the same for 2- and 4-barrel carbs. Even dual exhaust with only one 4-barrel had the same pump and 5/16” fuel lines but they moved the fuel lines to outside the frame rail away from the heat of the second exhaust pipes and muffler.
Only with the higher performance dual-quad and fuel injection 283 did it increase to a larger fuel pump and 3/8” fuel lines.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
05-19-19 08:35 AM - Post#2766712
    In response to YOUNG57
Also, the fuel sending unit at the tank was increased to 3/8” for the dual-quad and fuel injected performance 283 to match the fuel lines.
55nomad
55nomad
Loc: Spring, Tx
Reg: 12-27-02
05-19-19 12:14 PM - Post#2766722
Excellent, thanks for the fast response
Tom
Execution time: 0.008 seconds.   Total Queries: 9   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:57 PM
