Username Post: Headers for V8        (Topic#358856)
jvahila
Loc: Canton Ohio
Reg: 11-07-17
11-18-19 06:58 AM - Post#2780422
I'm doing a V8 swap in my 54 bel air. Would anyone know what long tube headers work well for this? I know there may be some clearance issues. Does anyone have experience with long tube headers? I see a lot of pictures with the Sanderson short headers but not much with long tube headers
Thank You
50hotrod
50hotrod
Reg: 07-25-11
11-18-19 07:42 PM - Post#2780470
    In response to jvahila
Nobody makes a set of long tube headers for a V8 in the stock frame of a 49-54 chevy car. This is why I suggest an early Camaro or Nova sub frame swap. You get a suspension upgrade and an assortment of exhaust options.
I went with fenderwell headers. These are the only store bought long tube headers that will work......BUT......they will not work with the stock steering. I installed a Heidt suspension also.
1950 CHEVY 2 DOOR 327 TRI POWER FENDERWELL HEADERS HEIDT FRONT SUSPENSION 700R4 TRANS 411 REAR
Member #51
11-18-19 09:44 PM - Post#2780474
    In response to 50hotrod
That is correct, there are no headers for a V8 in a 49-54 Chassis. SOME cast iron exhaust manifolds can be used with some trimming of the firewall braces, removal of the 49-54 style emergency brake linkage and a VERY GOOD, VERY EXPERIENCED muffler guy.
When I first installed a V8 in the 51 over 50yrs ago, I used 64-68 Chevelle/Camaro style manifolds, because they have a bracket for an alternator on the left manifold. NO, I'm sure they are not as efficient as a good set of headers would be, but they do a respectable job for my needs.
Even later style manifolds that have a similar style to the 55-56 manifolds will also work. But I do not like those because the spark plugs are not as easily accessible.
Attachment: 100_3583.jpg (77.6 KB) 7 View(s)
Attachment: 100_3584.jpg (78.76 KB) 3 View(s)
Attachment: DSCN2102.JPG (4.38 MB) 4 View(s)
Attachment: DSCN2160.JPG (478.96 KB) 4 View(s)
Attachment: 100_3562.jpg (67.08 KB) 5 View(s)
Member #51
11-18-19 09:53 PM - Post#2780475
And the last picture.
Attachment: 100_4114-1.jpg (62.76 KB) 5 View(s)
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
11-18-19 11:41 PM - Post#2780476
Over on the HAMB, a member "deto", modified some later model Camaro headers by cutting and welding on a new collector. I don't remember the specific year headers he used, and he has't been on the forum there for a while; there are NO bolt in, long tube headers, made for these cars (49-54), and the Sanderson's are't really a performance set of headers. They are designed to "work" for a swap. We used a set of "96, baby LT1, Caprice cop car manifolds". You have to remove the tin covers, plug/weld a couple of AIR ports, and drill another mounting hole for earlier heads (7 bolt heads to 6 bolt). These manifolds have individual runners, sweep up and then drop down at the rear; they are essentially a cast iron header. You still have to modify the firewall supports for clearance with them however. They look good, fit good, make power, and are what I'd use in building a 49-54 Chevrolet; we used them on the 51 Bus Coupe. They are used on some Camarons/Firebirds, trucks, and full size cars, and are available new from the aftermarket.
I am Butch/56sedandelivery.
Snegrah
"3rd Year" Platinum Supporting Member
Snegrah
Loc: Pacifica, CA.
Reg: 04-28-04
11-19-19 07:38 AM - Post#2780502
Anyone try these?
https://nam02.safelinks.protection.outlook.com/?ur...
Tom
51 Chevy Bus. coupe 261 6cyl 5 speed
53 Chevy Bus. coupe 350/700R/AC
49 Chevy P.U. 350/700R/AC
51 Chevy sedan delivery - project
eplantage
Loc: Southern MN
Reg: 03-15-04
11-19-19 11:06 AM - Post#2780515
    In response to Snegrah
Those are 55-56 style manifolds.
Age: 66 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
Cruzin Okie
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
11-19-19 11:16 AM - Post#2780517
    In response to eplantage
I thought 55-56 were Ram Horn?
Johnnie
1950 styleline deluxe sports coupe, 350 cid, TH 400, nova rear end. Gen IV Vintage air. SOLD!
1953 210 4 Door, 235 with Powerglide. All original except for the 1954 hood bird.
John 3:16
eplantage
Loc: Southern MN
Reg: 03-15-04
11-19-19 11:42 AM - Post#2780518
    In response to Cruzin Okie
57 were rams horns. 55-56 were "log" type.
Edited by eplantage on 11-19-19 01:21 PM. Reason for edit: No reason given.
Member #51
11-19-19 11:47 AM - Post#2780519
This is L & R 55-56 Chevy V8 style manifolds.
Attachment: index.jpg (4.06 KB) 5 View(s)
11-19-19 12:54 PM - Post#2780527
May be no help, but with a Fatman frt end, Ram's horn center dump manifolds fit nicely. Rack and pinion clears up space of course.
Snegrah
Snegrah
Loc: Pacifica, CA.
Reg: 04-28-04
11-19-19 05:59 PM - Post#2780550
I think the 56 style manifold dumps in the front on the driver's side? These both dump in the rear.
Member #51
11-19-19 06:45 PM - Post#2780554
The top manifold in the picture that I posted is for the right side, when it's turned around to be installed on the right side, and it dumps at the rear.
Snegrah
Snegrah
Loc: Pacifica, CA.
Reg: 04-28-04
11-19-19 07:16 PM - Post#2780558
Yes, I guess what I'm trying to say is 56's dump in front and in the rear. The Williams both dump in the rear. Has anyone tried these?
Execution time: 0.024 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:00 AM
