Username Post: Carb is too old        (Topic#357404)
Tanxane
Tanxane
Loc: French Riviera
Reg: 01-16-10
07-28-19 01:14 AM - Post#2771773
Hi, My car has been completly rebuilt (twice) but now, the carburetor seems to be too old. So I need to buy a new one. I've seen the Daytona UN2, do you have any advice ?
Thank you.
The story of my 54 Bel Air HT : Clic here
bobt
Loc: colonial heights va
Reg: 06-28-14
07-28-19 02:34 AM - Post#2771776
    In response to Tanxane
I LOVE my Daytona carb although it was very hard to dial in. The instructions that came with the carb didn't work for me. I'm running a stock 1954 235 engine in my 1951 Fleetline. The Daytona carb is a just a Holly knockoff made in Argentina. Bobt
Tanxane
Tanxane
Loc: French Riviera
Reg: 01-16-10
07-29-19 09:43 AM - Post#2771914
    In response to bobt
Thank you very much, I think I'm going for it.
Dave in VA
Dave in VA
Loc: SW Virginia, USA
Reg: 03-11-18
07-29-19 12:52 PM - Post#2771923
I bought a remanufactured carb on Ebay from Carburetor Exchange. Totally satisfied.
"Knowledge is Good" -- Emil Faber
U S Navy MM2 1970-75 USS Canisteo AO-99, USS Miller DE-1091 (The Champagne of Ships)
1950 Styleline Deluxe 2dr, mostly stock, driver quality...new to me 3/18
2016 Equinox LTZ
2017 Silverado LTZ 6.2
Airlifter
Airlifter
Reg: 06-07-15
07-29-19 02:53 PM - Post#2771936
    In response to Dave in VA
I have a Daytona on my 261 at present. I was using the same carburetor on the 235 before I found a Carter. The Daytona performs well but the gas mileage I not good at all. The best I ever got was about 11 mpg. With the Carter I got around 15.
I know that gas mileage shouldn't matter but my car is a daily driver.
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
carbking
carbking
Loc: Missouri
Reg: 06-14-03
07-29-19 03:25 PM - Post#2771941
    In response to Airlifter
Tanxane - I would respectfully disagree that your carb is too old; we sell rebuilding kits for carburetors in the 1920's, 1910's, and earlier every week.
Noted your location as France.
As I have no idea what might be available to you, I will make no recommendation; other than that if you lived in the USA I would suggest a Carter type YF.
Jon.
Good carburetion is fuelish hot air!
The most expensive carburetor you will ever buy.....is the incorrect one you attempt to modify!
If you truly believe "one size fits all", trying walking a mile in your spouse's shoes!
Tanxane
Tanxane
Loc: French Riviera
Reg: 01-16-10
08-02-19 08:55 AM - Post#2772236
    In response to carbking
Thank you for your advice.
I go quite often to California because my sister lives in San Diego.
I did rebuilt my carburetor in 2009 and it was working quite well after that. But in 2015 the car was completly flooded and it took me 2 more years to rebuild it for the second time.
But the water was dirty with acid and chlorine (pool house in the garage) and I think the carb didn't enjoy this treatment.
Are the carter hard to find ?
Edited by Tanxane on 08-02-19 08:55 AM. Reason for edit: No reason given.
carbking
carbking
Loc: Missouri
Reg: 06-14-03
08-03-19 04:44 PM - Post#2772337
Carter suggested the use of YF 2101 for the 1954 passenger with 235.
They show up fairly often on Ebay. You might have one shipped to your sister right before you visit.
Jon.
Tanxane
Tanxane
Loc: French Riviera
Reg: 01-16-10
08-05-19 08:03 AM - Post#2772447
Thank you very much, I'm going to look for one of these carb.
I drove my car yesterday, it very nice when I'm driving slowly on the sea front (30kmh/20mph) but it's not progressive when I throttle just a little.
And if I push harder, sometime the engine stop like there is no more petrol in the carb.
(sorry for my english).
carolina chevrolet
Reg: 11-12-18
08-05-19 11:06 AM - Post#2772457
A new filter and possibly a float adjustment might be all that carb needs.
40grit
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
08-05-19 08:39 PM - Post#2772504
    In response to carolina chevrolet
It sounds to me like the accelerator pump in the carb may be bad if it just does not want to accelerate without a bad hesitation. If that is the case it certainly is a simple repair.
Just Slightly Abrasive
Tanxane
Tanxane
Loc: French Riviera
Reg: 01-16-10
08-10-19 03:46 AM - Post#2772866
@ Carolina : The carb has been cleaned and rebuilt recently, after it's been flooded, The air filter is brand new but I'm going to double check.
@40Grit : I'll check that again as well.
Thanks.
Mirango53
Loc: France, Bordeaux
Reg: 10-07-16
08-16-19 06:12 AM - Post#2773298
Salut taxane, you changed the old carb finally? If you do it , what are you gonna do with that then ? You sell? And you have give another restoration a your car? In retromeca again? Do you have pictures or a vidéo of that?
Max- Bordeaux
Tanxane
Tanxane
Loc: French Riviera
Reg: 01-16-10
08-17-19 02:11 AM - Post#2773357
    In response to Mirango53
Hi Mirango,
No, For the moment the car is still running with the Rochester, I don't go anymore in Retromeca, After the flood, they did a bad work, I prefer doing it myself now.
Tanxane
Tanxane
Loc: French Riviera
Reg: 01-16-10
08-29-19 11:58 PM - Post#2774454
SO, Yesterday I drove 400 km (250 mi) and I had to stop twice on the road :
When I'm driving at constant speed, It's OK but if I need to accelerate, the carb seems to run out of fuel.
So, I think the problem is not the Rochester but the line.
I have the mechanical pump wich is in a very good shape, but before I have an electric pump with a timer for feeding the carb like a booster pump when I start the engine after a long stop.
Edited by Tanxane on 08-29-19 11:59 PM. Reason for edit: No reason given.
Dave in VA
Dave in VA
Reg: 03-11-18
08-30-19 06:12 AM - Post#2774466
Great video story on your car, but couldn't read the French. You basically rebuilt the car, so I'm surprised that you've got any problems.
The kiss on the cheek is so continental...
2016 Equinox LTZ
Tanxane
Tanxane
Loc: French Riviera
Reg: 01-16-10
08-30-19 08:23 AM - Post#2774472
The car was rebuilt, as new but...
in 2015 the drama.
The car and 4 of my motorcycles were flooded in the underground garage during 72 hours.
Watch this :
value="transparent">
So, I had to rebuild it again but you know, this dust is so thin that I still find some everywhere.
I wanted to make some improvement like new shocks with springs, new audio, good noise insulation ...
Edited by Tanxane on 08-30-19 08:27 AM. Reason for edit: No reason given.
Dave in VA
Dave in VA
Reg: 03-11-18
08-30-19 08:33 AM - Post#2774473
Wow, I had no idea what you've gone thru.
2016 Equinox LTZ
2blu52
2blu52
Reg: 03-12-02
08-30-19 10:12 AM - Post#2774476
You either have a vacuum leak or a float that is not set right.
THOMAS JEFFERSON
eplantage
Loc: Southern MN
Reg: 03-15-04
08-30-19 12:03 PM - Post#2774494
Wow, that's terrible. I can't imagine how you felt.
Age: 65 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
Tanxane
Tanxane
Loc: French Riviera
Reg: 01-16-10
08-30-19 12:45 PM - Post#2774497
    In response to 2blu52
Yes, I think about the float that could be a little low.
I'm going to check that.
Thank you.
I've found a Carter 2101s on ebay, I should recieve it around september the 25th.
During my last trip I did about 17,5 mpg but I was driving gently between 65 and 70 mi/h
Edited by Tanxane on 08-30-19 01:02 PM. Reason for edit: No reason given.
Tanxane
Tanxane
Loc: French Riviera
Reg: 01-16-10
09-14-19 03:45 AM - Post#2775491
I recieved my carb, it was sold as "rebuilt" but maybe that was 300 years ago. So I need to check it before.
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
09-14-19 05:48 PM - Post#2775523
I just finally overcame major issues with my car stumbling badly coming off idle. It was the floats. A few people said to check your float. Have you had a chance?
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
Edited by drew1987 on 09-14-19 05:49 PM. Reason for edit: No reason given.
Tanxane
Tanxane
Loc: French Riviera
Reg: 01-16-10
09-15-19 04:09 AM - Post#2775544
    In response to drew1987
Hi Drew1987, not yet, I will do that before I switch the carbs, And then I will compare the mileage between the two carbs.
drew1987
drew1987
Reg: 02-23-14
09-15-19 11:35 AM - Post#2775573
Yea that may reveal a lot. Also accelerator pump.
My hope for you is that they come out with a 1bbl bolt on fuel injection, like the 4bbl ones that have become popular, because it sounds like mileage matters. A quick glance and they don’t even appear to be different than a carb. A 1bbl one would be a blessing to guys running original 4 and 6 cyl or even flatheads with 1bbl
Member:
Airlifter
Airlifter
Reg: 06-07-15
09-15-19 07:00 PM - Post#2775609
I have ran a Rochester and Carter. Got much better performance and mileage with the Carter.
mahlmann
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
09-16-19 10:33 AM - Post#2775639
That reminds me of the Carb Kings ABC's of good carburation:
Always Buy Carter!
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'69 El Camino SS-396
'07 Ford F150 to haul parts for above
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
chevyivar
chevyivar
Loc: Norway
Reg: 08-30-12
09-16-19 02:10 PM - Post#2775653
Hi Tanxane.
Sorry to hear about the flooding.
I have all the photos from the first restoration of your 54, a huge inspiration for me since i have the same HT and the same paint combination as yours, the work you did on yours have helped me a lot.
Keep it up and good luck from Norvege:)
1939 Chevrolet Master Deluxe 85
1954 Chevrolet Bel Air Sport Coupe
1954 Chevrolet Bel Air Convertible
Tanxane
Tanxane
Loc: French Riviera
Reg: 01-16-10
09-20-19 03:46 AM - Post#2775938
    In response to chevyivar
Thanks guys.
@Chevyivar : If you need more pictures, I can send some.
Mirango53
Reg: 10-07-16
09-21-19 12:57 AM - Post#2776027
Salut taxane, that is terrible, 72 understands the water, i cant imagine, buy you make un other restoration, do you have pictures or vidéos ?
Ps i have un ht bel air 1953 and i have un sedán 2 doors 1954.
Execution time: 0.048 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:39 AM
