Tech420
Reg: 01-11-21
01-11-21 09:37 AM - Post#2811846
New to chevy talk recently purchased 48 fleetline has title current license plate but no vin plate inside. Only numbers found are on aftermarket stainless steel fire wall has a Briggs mfg co Detroit Michigan body tag that’s screwed on with Phillip heads the numbers on that plate match tittle. Is this a problem? Looked everywhere can’t find other tags or numbers on car or frame any advice appreciated thanks
TAT_2
Site Ambassador - Member #26 - "20th Year" Silver Supporting Member
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
01-11-21 02:23 PM - Post#2811865
In response to Tech420
YO !!!
BEST TO ASK HERE
https://www.chevytalk.org/fusionbb/showforum.php?f...
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANIV- RUBY RED- LT1/6-SPD/RAG TOP
QUOTE FROM HELEN
Maxbigblock
Site Ambassador -
Loc: Stuart, Florida
Reg: 12-16-01
01-12-21 05:39 AM - Post#2811906
Welcome to ChevyTalk!
Max
I'm originally from the ONCE great city of Flint, Michigan. The birthplace of General Motors, where A C Spark Plug was formed and headquartered, where the first Corvettes were hand built, and where my 1955 Chevy was made.
01-12-21 03:17 PM - Post#2811937
Welcome to ChevyTalk. What state issued the title and what state are you registering the car? Googled Briggs nameplate and some things came up. Some states issue their own ID plates, depending on the circumstances.
29-41, 42-48, 49-54 Moderator
1946 Chevy 1/2 ton pickup, stock. Purchased 11/18/17. Sold 9/16/20
2019 Ford Ranger Lariat Super Crew |
Humpback Panel
Loc: Vanderbilt Mi. Lake City ...
Reg: 12-10-08
01-14-21 04:50 AM - Post#2812042
Tech 420
If you are 100% SURE you did not buy a hot car you have several options
1) leave as is and re-title / tag in your name and have fun
2) find out what the location of the original plate was and
Have a new inverted tag made and install it . Many companies
provide this service.
3) go find a state policeman , pull him over and ask him if the
car is legal .... it’s kinda the. 420 thing to do and probably why
you missed the whole tag thing in the first place
Dan
Looking for any information on the Chevy One Ton Humpback Panel truck.... Anything would be helpfull |
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
01-14-21 06:37 PM - Post#2812101
Back when your car was new, many states used the engine serial number for title/registration purposes. The serial number plate should be screwed to the passenger A pillar between the hinges, closer to the bottom hinge. There should be a data plate riveted to the firewall that has nothing to do with vin/serial number. Go to www.chevy.oldcarmanualproject.com for more info. There are no “hidden” vin’s or serial numbers on the frame or body.
Edited by lofat46 on 01-14-21 06:40 PM. Reason for edit: No reason given.
Broo102
Loc: Huntington Beach, CA.
Reg: 09-30-14
01-16-21 03:46 PM - Post#2812220
I live in one of he most restrictive states in the USA & I bought a VIN plate from someone. They sent it to me with the last known VIN stamped on it. AAA looked at it and pushed it through. No problems
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
47 Chev. convertible in progress |
Tech420
Reg: 01-11-21
01-16-21 04:16 PM - Post#2812223
In response to Broo102
Good to kno. Can I ask what year vehicle and how was it attached thanks
55MAS
Loc: North Coast, USA
Reg: 12-19-01
01-17-21 01:34 PM - Post#2812271
May or may not apply to a '48. On my '40 5h3 VIN tag is inside the car on the passenger floor area under the mat.
Broo102
Reg: 09-30-14
01-17-21 03:10 PM - Post#2812278
47 Convertible, and the registration didnt even say that! AAA changed it to the correct yr, make & model, on top of the VIN plate change
What state are you in?
Thanks!
Bru
John 3:16
Edited by Broo102 on 01-17-21 03:13 PM. Reason for edit: No reason given.
