Do you have any installed photos for the '53-'54 Chevy front door power windows? I'm ready to order. Would love to see a photo of them installed before I place the order.
I do not have any installation photos of this item. The reason is this kit is so straight forward to install. The regulator bolts back in exactly where the old crank regulator came out. It attaches to the glass track exactly the same way. The only drilling required is to put the wire loom through the door into the cab. This is a very easy kit to install. We have these in stock. If you have any more questions please let me know.
Dusty
Nu-Relics
336-699-8949
Edited by Nu-Relics on 07-18-17 11:42 AM. Reason for edit: No reason given.
Yes these regulators bolt exactly where the factory crank window regulators are bolted in. They will also use the factory lower glass tracks. Just swap out your regulators and run some wires.
