T57
"13th Year" Platinum Supporting Member
Loc: NE Ill.
Reg: 01-07-06
08-27-24 01:58 PM - Post#2873125
Hi! I have a 57 with a 454 with 10.5 comp. pistons.
Any tricks to keep it cool? All was good untill temp hit 96.
Wqs wondering if some of you good folks might have an idea.If not, thats cool...Just thought I'd see.
55MAS
Loc: North Coast, USA
Reg: 12-19-01
08-28-24 06:28 AM - Post#2873155
In response to T57
Do you have a fan shroud? If not, it is the number one part to add. Cars have had shrouds since the later 1950s. The above assumes a proper 7-blade pump driven fan. No electrical fans are needed.
GreatNorthWoods
Reg: 03-31-02
08-29-24 02:17 AM - Post#2873204
In response to T57
Is it heating up on the highway or in-town driving? How hot? What fan do you have? What radiator? How far is the fan from the radiator? Shroud?
Vern
1930 DeSoto CK Business Coupe- 350 Chevy Crate V8, 4-wheel disc brakes, TH400, S-10 Rear, Heidt's IFS, A/C |
Bad56Sedan
"18th Year" Gold Supporting Member
Loc: Pasadena, Texas
Reg: 04-29-04
09-01-24 12:51 PM - Post#2873350
I wonder if T57 is using electric fan?
I wonder 1 fan or 2 fans?
I played the overheating game for a while,
wasted time and money then finally cured the issue,
overheating is the least of my worries now,
I finally bought the electric fans from LLeh,
now I have more time to worrying about people running into me while cruising.
VC56S 2 door Sedan, 44 Years
GreatNorthWoods
Reg: 03-31-02
09-02-24 01:09 AM - Post#2873366
In response to Bad56Sedan
"Now I have more time to worrying about people running into me while cruising."
Ain't that the truth!
Vern
T57
Loc: NE Ill.
Reg: 01-07-06
09-18-24 10:27 AM - Post#2873989
Hi all, sorry I've been away. A couple hospital stays set me back a bit... Okay, radiator, 2 14" electric puller fans with tight shroud, all are from Auto-rad.
Thermostat was a 180 deg. car would get as high as 225 deg after about 50 min. around town. I put a 160 deg stat in and it's better, but still gets to about 200 deg after about an hour or so just around town. I get that 200 is pretty hot but, doable. Thing is, it's around 78-80 deg outside. Wondering what will happen when it gets to the 90's. Oh yea,I should mention it has Vintage air.
Again, sorry for the hiatus, couldn't do much about it. Any help would be greatly appreciated.Thanks in advance.....Tom...
Edited by T57 on 09-18-24 10:33 AM. Reason for edit: No reason given.
japete92
Loc: No. Virginia
Reg: 01-18-13
09-18-24 11:48 AM - Post#2873994
In response to T57
With what you seem to have, the engine is entirely reliant on the electrical fans to provide air for the heat exchange (from coolant to air within the radiator) needed to keep the coolant at the proper temp.
Question: Do you have a radiator? It is really hard to see one.
Fans need to start at the 'high' temp and run until the 'low' temp is reached. My opinion? 'High' is about 115% of the thermostat rating. 'Low' is about 90% of thermostat rating.
And you will need enough CFM to do the job. I can't help with that number. I've never used electric fans on engines designed for mechanical ones . Such engines allowed enough air flow through the radiator (the heat exchanger) at forward moving speed to maintain the coolant temp at the thermostat rating with very little variation. The fan on those systems mainly were installed to assist in 'traffic/idle' modes of operation.
Pete
09-19-24 04:41 AM - Post#2874008
In response to T57
With a fan set up and radiator to fit that core support, you don't have a radiator/air flow problem, IF, the fans are turning the right direction. I have a similar size, cross flow, with 2 smaller fans than that and it runs at 180 degrees with A/C on in 110 degree Texas heat, all the time.
I would look at engine problems such as mixture, timing, clogged coolant passages, collapsing lower hose, restricted exhaust.
T57
Loc: NE Ill.
Reg: 01-07-06
09-20-24 11:08 AM - Post#2874032
In response to acardon
Thanks, Pete, and Don.
I'll try to get better pix, and more accurate info. FYI, It does have two stats, one low temp, one,high temp. Don't know the degree's right now.
Again, Thanks!....Tom...
elvis
Loc: Ontario
Reg: 11-10-05
10-17-24 05:25 PM - Post#2874793
If I may hi-jack this thread for a moment. How does one check for clogged coolant passages, collapsing lower hose and restricted exhaust?
Pouring money between the wheels. |
